Replace Smog valve cover with Non-smog - concerns
- MekonFear
I've got an 1983 kz750 LTD which has had the smog valve cover (i.e one with the reed valves installed at top front) replaced with a standard ( or UK standard without emissions control ports) instead. Having read the below quoted thread, re: a 550, I was concerned as nothing had been done to mine other than swapping the rocker/valve covers - i.e no other holes have been plugged internally. My understanding is that the kz engine is just that - no difference between the UK and US models and therefore, a non-reed ported valve cover is fine to to put on as we have no similar emissions regualtions and the engine is the same internal design regardless. in the thread below there is a parts diagram from Aric - I have basically swapped the upper cover for the lower one in the diagram( albeit for a 83 H4 model)
kzrider.com/index.php?option=com_kunena&...85202&catid=3#185202
Please read this thread as it should demonstrate what I'm talking about better.
WiredGeorge - you say in the above threads that there seems to be internal differences under the valve cover, or am I misunderstanding?
The bike has only been running for 15 minutes in 7 months of owning it as I've been trying to do an extensive restoration and repaint - just getting to the engine gubbins now, hence sudden paranoia!
Any thoughts and advice, gratefully received in advance.
Cheers
Ben ( Nottingham UK)
- steell
I'll go look and be right back.
Ok, here's the deal;
If the cam cover you are using has four protrusions that cover up the emission ports (if your 750 head has them), then you're fine.
If you can see four holes in the head, one directly behind each exhaust valve, while the cam/valve cover is in place, then you need to plug those passages.
I have absolutely no idea whether the US and UK spec motors are the same, but I rather doubt it.
- darmahsd
I think when I adjust the valves and have the old cover off, I'll plug the holes anyway. Can't hurt.
Stephen
- MekonFear
I'll check tonight as to whether or not there are protusions blocking the holes. There are definately no holes showing with the valve cover in place, but I don't know if the ports are actually blocked under the cover - maybe this doesn't matter? so long as the ports are not exposed and are under the valve cover.I'll report what I find.
Thanks for your help.
Now to sort out the choke that doesn't work. And dead master cylinder.And centre stand dangerously close to the chain. And... ;o
Cheers Ben.
- MekonFear
Just to clarify, I have a US bike/engine but have put a UK valve cover on it.
Cheers
- wiredgeorge
- Jack
- Thank you received: 7
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- wiredgeorge
- MekonFear
Well I can't see 'em so I'm officially stopping worrying.
- Jack
Don't know,but I'll look at my buddy's bike he just bought from the US,the previous owner had bought a Canuck rocker cover to eliminate the smog ports.I've never had a US casting head apart.Jack, That is good. Do the Canadian spec valve covers cover the ports that lead down to the exhaust runners on a US spec cylinder head? If not, then the ports must be plugged in some fashion and the valve cover will essentially be a 77/78 valve cover except the well where the cam chain idler sits will be bigger as the later heads had a bigger idler assembly and the earlier valve covers won't fit unless the older idler assembly is also used.
79 KZ 1075 MKll
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- kawsakiman
- Thank you received: 6
the first cover is off a 77 650.
it has no provisions for the smog set up.
look at the top part of it. see how there are no holes?
[img size=150][/img]
- kawsakiman
and here is one from canada for a gpz.
it has the block offs on the top.
see the four holes?
they go nowhere, they just block the exhaust.
you must either drill and tap them for a pipe plug or find another way to plug them or they will leak exhaust if you use an early cam cover on a later smog head.
look for a canadian cover. but they are really hard to come by.
hope this clears this up for you.
