starter nut
- Bdog
- Sweep the leg johnny!!!
starter nut
20 Sep 2008 07:23
I am picking up a motor that was fitted with a starter nut and total loss electrical. To swap it back I should only need to reinstall a stator and stuff right? Also, is the stock starter enough for a 810 kitted motor or is there something I need to swap it out with? Thanks in advance.
Brandon
Brandon
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- donthekawguy
Re: starter nut
22 Sep 2008 04:27
You will need the stator, rotor and cover. You will also need all of the stuff that comes on the panel that fits under the left side cover to start with. I'm guessing the bike was used for drag racing so who knows how it has been molested. Parts are cheap so it shouldn't be a big deal to fix.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- trippivot
Re: starter nut
22 Sep 2008 07:48
the starter clutch inside the engine might have a little extra stress on it depending on the compression level.
pop the belly pan off and look inside to verify the starter clutch is even in there..
