- Thank you received: 13
what the frick. clutch won't release.
- Sandy
- Fly High,Tony
11 Sep 2008 07:07 #236685
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic what the frick. clutch won't release.
Well you disconnected the clutch cable FROM the mechanism(to put the new cable on,right)and a lot of times,that mechanism will move to a different position.
If you didn't remove the clutch push-rod,then you should be ok,as far as that ball bearing goes.
We'll have to wait until you can get that battery charged up again,and take it from there.
1977 KZ1000 A-1
- ghunt81
11 Sep 2008 09:26 #236692
by ghunt81
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
Replied by ghunt81 on topic what the frick. clutch won't release.
Oh, I didn't put a new cable on. Actually, after I disconnected the cable, I hadn't even played with the adjusters on the cable...I just disconnected it, and then hooked it back up when I put the cover back on, but it wouldn't work.
