what the frick. clutch won't release.
- ghunt81
08 Sep 2008 20:35 #236256
by ghunt81
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
what the frick. clutch won't release. was created by ghunt81
I put my starter clutch back together today and put the cover back on, and then put the clutch cover back on.
Something told me to make sure the clutch worked OK...well, I checked it and it doesn't. The clutch doesn't release when you pull in the clutch lever.
Was I supposed to do something in particular when I put the clutch cover back on?
- Sandy
- Fly High,Tony
- Thank you received: 13
08 Sep 2008 20:55 #236259
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic what the frick. clutch won't release.
Was the clutch release mechanism installed correctly?
1977 KZ1000 A-1
- Sandy
- Fly High,Tony
08 Sep 2008 20:58 #236260
by Sandy
- ghunt81
08 Sep 2008 21:12 #236262
by ghunt81
Replied by ghunt81 on topic what the frick. clutch won't release.
I never took it apart or did anything to it. All I did was disconnect the cable when I took the cover off.
- Sandy
- Fly High,Tony
08 Sep 2008 21:20 - 08 Sep 2008 21:21 #236266
by Sandy
1977 KZ1000 A-1
Yes,but if you didn't have that release set up properly when you reinstalled the cable,then it won't apply any pressure to the clutch-rod,which applies pressure to the clutch plates.
What I mean,is that the mechanism has to be positioned properly when you install the cable,and put the cover back on the engine.
1977 KZ1000 A-1
Last edit: 08 Sep 2008 21:21 by Sandy.
- ghunt81
08 Sep 2008 21:26 #236267
by ghunt81
OK well I wasn't aware of that and that's what I was wanting to know...so how exactly is it supposed to be positioned?
It feels like it's putting pressure on the clutch rod. I dunno.
- Sandy
- Fly High,Tony
08 Sep 2008 21:27 #236269
by Sandy
1977 KZ1000 A-1
How does it feel at the lever?
Does it feel like it did BEFORE you pulled it all apart?
Does the lever pull in with the same resistance as before,or is there slop(play) in it?
1977 KZ1000 A-1
- Sandy
- Fly High,Tony
08 Sep 2008 21:29 #236270
by Sandy
1977 KZ1000 A-1
The final clutch adjustment(numbers 1 and 2 in the pic I posted)...you might have to do some adjusting there,perhaps.
1977 KZ1000 A-1
- ghunt81
09 Sep 2008 06:16 #236300
by ghunt81
It pretty much feels like it did before, yeah...No slop, has about the same resistance.
Also...well, it's hard to get at the adjuster because someone who had the thing previously rounded out one of the screws that holds the cover on for that...and I'm not quite sure how to get it out (I don't have a screw extractor). I would cut a slot in it but I won't be able to do that without cutting the aluminum around it.
- Sandy
- Fly High,Tony
09 Sep 2008 07:23 #236312
by Sandy
1977 KZ1000 A-1
You're gonna have to get that cover off,Garrett...for sure.
You need to rule that adjustment out,with what you have going on right now.Sometimes,it only takes a slight turn of that screw to make a world of difference.
Not saying that THAT'S what's going on,but you have to get in there to see for sure.
Do you have an impact screwdriver?
Can you use another type of screwdriver,and tap it with a hammer(gently) to get it to bite?
This will be a final adjustment,after you've ruled out all other possible causes.
Lets not forget that worm-geared clutch release mechanism either.
If that wasn't positioned properly when you put it back together,then that will cause problems,like you're describing.
As soon as you disconnected the clutch cable from that gear,it may have moved to a different position,and you may have moved it to another position(wrong position)when you put it back together.
1977 KZ1000 A-1
- ghunt81
09 Sep 2008 09:09 #236328
by ghunt81
Well, I'll have to see what I can do with it tonight.
How IS the clutch release supposed to be positioned? I have a service manual that just shows a picture and says "position it like this" but the picture really doesn't tell me a damn thing.
- Sandy
- Fly High,Tony
09 Sep 2008 17:57 #236410
by Sandy
1977 KZ1000 A-1
Can't say for sure,Garrett.
It's more of a hands-on procedure.
You have to position the part that rotates,to where it is about mid way in the other half of the work gear.
Turning it out too much or not enough won't work.It has to be in the mid range,approximately.
And you HAVE to get that cover removed,so you can do a final adjustment on the clutch,there.
And don't forget...we might not even be looking in the right area,as you could have an issue elsewhere,but lets get this part figured out first.
1977 KZ1000 A-1
