Tach leak or oil leak
- Monty Burns79
05 Sep 2008 10:45 #235649
by Monty Burns79
1983 KZ750K LTD Belt drive
Dover, NH
Tach leak or oil leak was created by Monty Burns79
I have noticed i have some fluid leaking from my tach cable and where it attaches to the engine. Is it a dry tach, and if so does that mean it is oil from the engine? It seems it is coming from the tubing that fits over the cable, not a huge problem just would like it resolved. Every so often it drips on my front fender.
KZ750K LTD Belt
Thanks guys
KZ750K LTD Belt
Thanks guys
Dover, NH
- MFolks
- Thank you received: 540
05 Sep 2008 12:38 #235661
by MFolks
Replied by MFolks on topic Tach leak or oil leak
Go to
www.z1enterprises.com
and ask about tach drive oil seals. Kawasaki tried to use as many parts as possible through the various bikes as they could to keep costs down.
The oil seals may be the same as used on the KZ's and Z1's and smaller bikes.
- Thank you received: 2098
05 Sep 2008 13:29 - 05 Sep 2008 13:49 #235667
by Patton
Replied by Patton on topic Tach leak or oil leak
As MFolks suggested, here's the link to Z1E's tach drive seal (shows KZ750 application among other models)
Z1E's tach seal
According to Kawasaki.com's cross reference, the same part number 92050-075 tach seal is used on numerous models.
When the seal is functioning, it prevents oil escaping from underneath the valve cover through where the shaft on the tach gear spins inside the tach guide. Am uncertain how the KZ750 tach guide fits onto or into the engine, but thinking an o-ring prevents oil from escaping between the tach guide and engine.
On the large fours, no oil should escape through or around the tach guide even when the tach cable is not attached (can see the gear shaft split end spinning around with no oil escaping). Am thinking this would also be applicable to the KZ750.
Some owners employ gaskets or packing to tightly seal the connection where the tach cable attaches to the tach guide at the engine, so any oil escaping from the engine through the tach seal simply runs into and inside the tach cable. This doesn't "fix" the faulty seal, but keeps escaping oil off the engine. But doesn't catch any oil escaping between the tach guide and engine (due to a faulty o-ring).
Good Luck!
Z1E's tach seal
Good Luck!
Last edit: 05 Sep 2008 13:49 by Patton.
- Biquetoast
- King Jeremy The Wicked
05 Sep 2008 16:22 #235695
by Biquetoast
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
Replied by Biquetoast on topic Tach leak or oil leak
Patton wrote:
...*this* owner, too.
I just stick an o-ring (10mm, I think?) inside the hole where the cable screws in, re-attach the cable, and no problem.
....Some owners employ gaskets or packing to tightly seal the connection where the tach cable attaches to the tach guide at the engine, so any oil escaping from the engine through the tach seal simply runs into and inside the tach cable. This doesn't "fix" the faulty seal, but keeps escaping oil off the engine. But doesn't catch any oil escaping between the tach guide and engine (due to a faulty o-ring)...
kz750twins.com
