- Thank you received: 4
Set the tension on my cam chain - now it sounds like its sawing itself to pieces.
- themachine
and if they break, well, bad things usually result.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- Philip Meaney
"Chainsaw" noise is engine running with really loose chain
Gets better because the tensioner eventually takes up slack.
Bike seems to run fine but gets worse as it warms up - I had a DOHC car behave exactly the same when I replaced the timing belt and had one of my cams off by a tooth. Maybe one of the cams on you bike jumped a tooth.
If I'm right, all you need to do is pull off the cam cover and check your timing.
Only thing I've ever done to adjust my cam chain on any bike (except for my turbo which has a manual tensioner) is turn the crank so the chain slack was at the tensioner, loosen the bolt on the tensioner (if required), and tap the tensioner with a screwdriver handle in case it was sticking. Not sure what the Clymer manual suggests.
Just a thought.
80 750 H1
85 750 Turbo
84 GPz 750
- Rickman
- Thank you received: 1
After I changed the exhaust ghaskets, it started puffing back through the carbs.
Exh gaskets can be a real b*tch to keep in the right place while holding in the split keepers and tightening down the collar. Have you double-triple-quadruple checked that these are all in OK?
HTH,
Ricky
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
- Thank you received: 2098
... bike was running fine, it started up and I would ride it daily... attempted to fix it again and after I fired it up it sounded perfect. I took the bike for a ride and got about 1 mile and it died. It didnt sound terrible, it just quit. I took about 5 mins and it started on full choke, but would die if I gave it any throtle or attempted to close the choke. I managed to limp it home...Any advice?
Might be a fuel supply problem, such as:
Out of gas;
Petcock clogged;
Inline fuel filter clogged;
Fuel tank cap VENT clogged.
Good Luck!
- APE Jay
- Banned
- Thank you received: 58
- KOOL RYDER
- KZ 650B2 / KZ 1000E
I ordered a new tensioner with ghasket from ape , last Monday.
I ordered a valve cover ghasket + fuse assembly from Z1 wednesday.
Saturday the Z1 package showed up.
Man they are great.
Anways once the tensioner shows up i am going to install the tensioer and pull the valve cover and take a peak inside.
Anthing I need to be aware of when I pull the valve cover?
Do I need to put ghasket sealer on the cover or will the new ghasket work fine?
KR
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- Rail
