Set the tension on my cam chain - now it sounds like its sawing itself to pieces.
- KOOL RYDER
- KZ 650B2 / KZ 1000E
The bike was running fine, it started up and I would ride it daily.
After I changed the exhaust ghaskets, it started puffing back through the carbs.
I decided to tension the cam chain to see if it would resolve these issues. After following the procedure in clymers manual I fired it up and it sounded like a chainsaw was trying to cut the engine block in 2 so I shut it down.
I attempted to fix it again and after I fired it up it sounded perfect.
I took the bike for a ride and got about 1 mile and it died.
It didnt sound terrible, it just quit. I took about 5 mins and it started on full choke, but would die if I gave it any throtle or attempted to close the choke.
I managed to limp it home.
Anyways......I think I am in for it. I have ordered a tensioner from ape, and a new ghasket for it.
Any tips on how to pull the tensioner and reinstall?
Any idea why it would be puffing back through the carbs? Too much back pressure maybe? Could it be that I installed the wrong exhaust ghaskets?
I am going to pull the valve cover to see if I can resolve the issues I am having with it once the tensioner arrives.
Any advice?
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- Link14
- Thank you received: 6
My next step was to pull the automatic tensioner, clean it up really well and reinstall it, but given Kool Ryder's experience, I'm nervous about pulling the tensioner now.
- Thank you received: 2098
Also, a too tight intake valve clearance (i.e., valve isn't properly sealing against its seat when closed) may allow some combustion past the leak and back out through the carb.
Imo, the puffing back through the carbs isn't being caused by either too much back pressure or wrong exhaust gaskets. The wrong gasket would leak and be obviously noticed from the noise.
Good Luck!
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- Silver
- Old Bikes Are Better!
1983 KZ750F1 LTD
- themachine
- Thank you received: 4
hold the throttle wide open and make sure you have all the other plugs out while your cranking it
if its low, you will either have to adjust the valves or have the head rebuilt (bent valves)
more likely you'll have to adjust the valves,a fairly straightforward thing to do, check your book or look it up on the site.
but perform a compression test asap, hold the throttle wide open and make sure you have all the other plugs out.
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
Chain slip a tooth from the tention being too loose the second time?
that what I think it sounds like. I would guess the initial problem (puffing through the carbs) was unrelated to the timing chain, buuut some how things went south when you adjusted. I would pop the cam cover and check the valve timing before going further.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- dkmk
- Thank you received: 18
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
- RonKZ650
- Thank you received: 240
I've never used the APE manual adjuster, but would try to stay with the Kawasaki manual if possible, as it works just fine.
- MDawnz1
- Thank you received: 27
First things first ,
Start with the easy stuff ,
Whatever happened ,happened while you had it apart ,,
You know what you took apart .
Are all the plug wires on the right plugs ?
Is something under the tank pinched ?
A plug wire or fuel line ?
Did you unplug or move any wires while you had it apart ?
Is there enough clean oil in it ?
Does your oil pressure light work ?
Maybe change your oil & filter and LOOK for little pieces of black plastic or metal .
Its all cheap and almost no work .
1974 Z1a, still 903
- KOOL RYDER
I was told by the mechanic who looked at my bike a year ago that the tensioner was on the way out. That is the reason for the new one.
I realy think that I did the adjustment right, but i think that the tensioner is at fault.
I lined up the timing plate (corner just past the 2-3 mark) 2 revolutions back to mark, back out the tensioner bolt and all the slack should be taken up.
My logic is that if I followed the instructions properly and the tensioner was suspect all along, then it must be the culpret.
So, what is the easiest way to remove the tensioner? It is held in place with 2 / 10 mm bolts that are not easy to reach, anyone have any suggestions?
Will I have to pull the carbs to access the tensioner, or is it possible to install without doing so.
I am learning the hard-way.
KR
1978 KZ650B
1979 KZ1000ST
- RonKZ650
