Bog at high rpm's
  • civilengr3
  • civilengr3's Avatar Topic Author
Bog at high rpm's
03 Sep 2008 11:25
#235309
Bike runs good and strong between 2500-7000 rpm. At between 7-8k it seems to really bog down and run rough, but then picks back up around 8000-8500. I've not had it above 8500, kind of a little scared to go higher. What could be causing this?
Also below 2500 it kind of bogs too. Like I need fairly high rpms to take off, and starting on a hill from a stop is nearly impossible. Not sure if that'd be related.
1977 KZ650C
East TN
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Bog at high rpm's
03 Sep 2008 11:33
#235314
Did you clean out the carbs yet? I checked another thread you had about the Stale Gas The stale gas may have fouled up the pilot jet (under 2500 rpm problem) and the main jet (over 7000 rpm problem)
Cashion, OK
78 KZ650 B2 85,000+ miles
  • civilengr3
03 Sep 2008 12:57
#235322
Well, no... hadn't done that yet:unsure:
I'd say you nailed it. Guess I'll venture into another unknown this weekend. But, learning is one of the things I love about owning a KZ.:P
1977 KZ650C
East TN
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
03 Sep 2008 18:15
#235361
Ma Kaw says that you have a points ignition. Is that correct? If so my bet is that your problems are unrelated. The low RPM problem is caused by the idle circuit. Either misadjusted, blocked or just plain the wrong jet. The high RPM problem is caused by the points breaking down at that RPM. My 900 still has the same problem. The points have to be at top shape and perfectly adjusted to run at that speed cleanly.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • reborn650
  • reborn650's Avatar
03 Sep 2008 19:43 - 03 Sep 2008 19:44
#235374
It might be a good idea to take off the carb boots (the rubber intake manifolds connection the carbs to the cylinder head) and resealing them with a silicone adhesive. These rubber boots eventually will dry out and crack without being visible.
I noticed that when I had a minor air leak the motor sometimes stumbled at high rpm. This is a very simple task and can save you some headaches down the road.
Cheers - Colin Firth
1977 Kz650 Custom - 14,000 original miles, bought new by brother in 1977. Current re-incarnation includes- 810 Wiseco, WG Mikuni 29 Smoothies, 750 GPz cams, intake valves, modified head, Dyan ignition and coils, plus too much more to mention. Painted Moon Dust Silver to re-create factory paint scheme. Not much can keep up with this old girl up to 70 mph. This bike will never be sold and probably passed on to my teenage son when his testosterone levels off!
1982 Ferrari 308 GTSi. 3.0 litre, aluminum V8 Four Cam Engine with a sweet shifting five speed. Rosso Corsa Red with tan leather interior. 56,000 miles. Looks and rides like it just came off the showroom.
2007 Toyota FJ Cruiser. The yellow tank that will go anywhere-anytime!
1998 Jeep Wrangler TJ - 6 Banger with a five speed.
2007 Chevy Uplander (for my bride)
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
Last edit: 03 Sep 2008 19:44 by reborn650.
