How much oil is supposed to be in the starter case?
- ghunt81
03 Sep 2008 07:05 #235272
by ghunt81
1978 Kawasaki KZ750 Twin- Coil mod, Dyna coil, 7mm copper core wires
How much oil is supposed to be in the starter case? was created by ghunt81
Just wondering...I took my starter cover off last night, since I'm having problems with my starter slipping...anyway there was no oil inside the case there and I was just wondering if there was supposed to be or not.
- RonKZ650
- Thank you received: 240
03 Sep 2008 07:20 #235277
by RonKZ650
Replied by RonKZ650 on topic How much oil is supposed to be in the starter case?
No oil in there.
- steell
03 Sep 2008 18:17 #235362
by steell
Replied by steell on topic How much oil is supposed to be in the starter case?
RonKZ650 wrote:
Only because there's a drain that allows it to flow back into the oil pan
No oil in there.
