Best Bang for Buck Rebuild?
- iroc355
i just want a reliable consistent bike that will run respectable times.
- PLUMMEN
- Thank you received: 104
my hero!:laugh: build an 1197 following the Larry C bodybuilding plan!The only reason to put a J head on that bike is so you can spend more money on a center idler.....what's that get you?
Stay with your KZ head, put a 1075 kit with drop in cams with those 29's and you'll have a great little street bike.
J heads are pushd on here like they're some magic potion or something. That's pure bullshit unless you're going with bigger carbs and porting. Aske me how I know..
Larry C
- iroc355
still havent decided on what to do as far as a head, its beginning to seem that the kz head is just as good if you got to do porting anyways.
so now back to my decision on whether or not to go with 10.5 or 12:1..........
- racer54
- Thank you received: 114
- Bicycle Lee
Ya know, I NEED to sell this j head before I can send you my head to be fixed... why ya gotta put the kaibash on my deal???!!!!
And to think, I was THIS close to getting this thing sold and my head out to you.
for shame
1978 KZ1000 police
- iroc355
- Bicycle Lee
Tastes great or less filling?? Seriously.
the choice is yours, iroc.
You know how to reach me.
I'm going to list the head on ebay, but if you want it let me know. You would NOT be disappointed with the result.
1978 KZ1000 police
- PLUMMEN
high compression plays hell on cranks and cylinder studs.the cranking compression is the number you really need to worry about,10:1 and 12:1 are just general numbers.ive run more than one 13:1 1197 with big choppy cams/lots of overlap in streetbikes that started easier than motors with smaller cams :laugh:The KZ motor likes compression. A 1075 motor at 12:1 should be able to use the stock starter also. Never done it myself but lots of guys are starting bigger motors with the starter. Only deal is the fuel. The 10.5:1 motor would probably be able to use good pump gas which is LOTS cheaper then race gas. Lower compression would be easier on parts also. Higher compression would give you more torque which basically equates to more HP so.....
- zombiescustoms
Now I bought a $100 J model head, did the cam tower conversion and will do some mild porting, so I will have a 10:1 moter with a better flowing head for thoes huge carbs!
Good luck on you choices, if I were not on such a budget(read, cheap ass) I would big block mine but now I just want something to ride!
