Engine removal?
- Sail
Does anyone know whether it possible to remove the engine without removing the cover?
It is a 78 KZ750 B3.
Thanks for the advice!
1978 Kawasaki KZ750 B3 Twin
- Bluemeanie
- Thank you received: 14
- Sail
Thanks, I have faith!Hang on, steell is the resident 750 twin guru. He'll chime in for ya...
- steell
That motor is a tight fit in the frame, you have to tilt it to get it out/put it in, and there is only one position that will allow it to slide into the frame. A 650/750 four is a piece of cake compared to the 750 twin.
- Sail
I planned to un bolt it all , lay it down on the left side and wiggle the frame off but I guess I will pull the cover off!
Thanks for the advice, I appreciate it!
- Sail
Remove all the engine mounts, lay the bike on it's right side, has to be the right as there is one engine mount welded to the left side. Slide the frame down a bit and it comes out nicely.
- steell
Comes out easily!
Was this with the cam/valve cover still on??
I've never installed or removed a motor by laying the frame on it's side, since there are usually two of us here (and we're both pretty big guys), we just pick up the motor out of the bike and put it back in the same way.
- ronjones
- Thank you received: 4
Sail wrote:
Comes out easily!
Yeah, Steve, since I pretty much have to work alone, this is the method I used. I used a come-a-long, hooked to the garage rafter, and just lifted the engine right out. Needed to wiggle the frame around a bit to totally free it. Put it back in the same way.
