Oil coming from head gasket
- 77_650B1
28 Aug 2008 08:27 #234419
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Oil coming from head gasket was created by 77_650B1
Hi. I have what looks like oil coming from my head gasket area on number 4 cylinder. Is this even much of a possibility? Or is the engine screwed beyond all belief? All I can figure is valve seals gone, or rings gone, but she seems to be running ok.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- BSKZ650
- Thank you received: 14
28 Aug 2008 09:15 #234426
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Oil coming from head gasket
have you tried to retorque the bolts to se if that may help?, but in the long run you will probabaly need to pull the head and replace the gaskets, while you are in there change the valve seals and check the timing chain guides
- Thank you received: 2098
28 Aug 2008 09:55 - 28 Aug 2008 09:57 #234436
by Patton
Replied by Patton on topic Oil coming from head gasket
Would also closely inspect tach drive. And assure exhaust clamp nuts are tight with no exhaust gasket leakage. Sometimes the half-moon plugs or faulty valve cover gasket allow oil to seep through.
Once oil from anywhere migrates about the cooling fins, it's often difficult to locate the leak source without a thorough engine cleaning, and inpection (after drying) while the engine is running.
While oil might indeed be coming through the head gasket, and first appears to be coming from the head gasket, it is very often found coming from somewhere else (with a sigh of relief :lol: ).
Good Luck!
Good Luck!
Last edit: 28 Aug 2008 09:57 by Patton.
- 77_650B1
28 Aug 2008 11:48 #234451
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Replied by 77_650B1 on topic Oil coming from head gasket
Thanks for the advice guys. If I can get my carb issues sorted out, I'm gonna drive her for the rest of the fall if I dont get a whole lot of oil coming out over the next two months. Then she's getting a whole top end rebuild and new piston rings and a hone over the winter. I just wanted to knwo if she'll blow up on me any time soon, and by your replies chances are she probably wont, especially with this tiny amount of oil.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Thank you received: 2829
28 Aug 2008 16:29 #234507
by 650ed
Replied by 650ed on topic Oil coming from head gasket
What is the location of the leak (front of engine, side, back?) This may be an extremely easy fix if as Patton suggested it's leaking from the front where the tach drive is. Ed
- 77_650B1
28 Aug 2008 19:01 #234524
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
I dont know the exact location, but theres a growing film of oil on the fins on the side of the engine just under the split for the head gasket. I've pretty much decided to rough it out until the winter, when the engine's getting rebuilt in any event, I was out for a large run tonight with minimal growth of that film of oil.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- RonKZ650
- Thank you received: 240
28 Aug 2008 19:54 #234528
by RonKZ650
Replied by RonKZ650 on topic Oil coming from head gasket
Sounds like the rubber oval shape orings have hardened. Gotta love all the rubber seals used by Kawasaki:angry:
- larrycavan
- Visitor
28 Aug 2008 19:56 #234529
by larrycavan
Replied by larrycavan on topic Oil coming from head gasket
Want to pin point the exact source of the leak?
Before you put the bike up for the season, clean all the oil from the area. A can of brake clean will work fine for that.
Spray the suspected areas with spray foot powder. Then run the engine. The powder will turn brown and allow you to pin point the source of the leak.
Temporarily plugging the crank case breather will pressurize the engine and allow you to spot the leak. Bring the RPM up to about 1700 RPM for a couple of minutes. That's all it should take. If it doesn't show up by then, a quick, short ride should do the trick. REMEMBER to unplug the breather when you're done.
Guaranteed to find that leak. Especially helpful when its in an area where it gets blown around by the breeze.
- Sandy
- Fly High,Tony
- Thank you received: 13
- donthekawguy
- Thank you received: 8
28 Aug 2008 23:28 #234546
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic Oil coming from head gasket
Hey Tony should have tried that. :laugh:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- BSKZ650
29 Aug 2008 05:09 #234566
by BSKZ650
you said you were going to rering the engine, the 650s are damn near impossible to get stock rings for them.
but when you pull it down the first thing to do is mic the bores, in the long run you will prob be boring it out and new pistons and rings.
- Sandy
- Fly High,Tony
29 Aug 2008 07:42 #234597
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Oil coming from head gasket
donthekawguy wrote:
He DID,Don,but he kept using spray deodorant!:laugh:
(Billy Tucker)
(Billy Tucker)
1977 KZ1000 A-1
