ZR-7, GPZ, z750
  • JR
  • JR's Avatar
Re: ZR-7, GPZ, z750
14 Feb 2006 18:50
#23914
I took a good look at a zr-7 about 2 years ago at a dealers in Toronto. The bike was used but in very good shape. The engine seemed almost identical to my current ride but a lot smoother - then again it was 20 odd years younger. Performance seemed about the same. It think it was a tad heavier. Handling was good. The sales guy said hp was about 75 which suited me and also for insurance purposes it was not high rated like a crotch rocket. Over all a very nice bike. A more modern version of the old KZ750. Anyway. I decided not to buy and stick with the old beast. Maybe one day when the beast finally dies I'll look for a zr-7.
Take a look here www.zr-7.com/ and see the reviews.
Woodstock ON Canada
1980 kz750E1, 4->1, K&N pods.
  • lowbuck
  • lowbuck's Avatar
Re: ZR-7, GPZ, z750
14 Feb 2006 19:50
#23952
Here's what I'd like to try sometime... z750s w/zephyr bodywork. Old style, new stuff. Forgive the quickie photoshoppin'.
Post edited by: lowbuck, at: 2006/02/14 22:55
  • lowbuck
  • lowbuck's Avatar
Re: ZR-7, GPZ, z750
14 Feb 2006 19:58
#23955
Try again...
  • lowbuck
  • lowbuck's Avatar
Re: ZR-7, GPZ, z750
14 Feb 2006 20:00
#23956
original
  • Snakebyte
  • Snakebyte's Avatar Topic Author
Re: ZR-7, GPZ, z750
15 Feb 2006 02:53
#24003
That looks cool
  • AHRMA120
  • AHRMA120's Avatar
Re: ZR-7, GPZ, z750
17 Feb 2006 09:06
#24479
The original ZR-7 of the early 90's up to the point where they threw the old zx-7 motor in the frame are essentially the same as kz, gpz motors. The reason the horspower was done is due to EPA milder cams less compression and CV carbs. A zr-7 motor will bolt into Kz Frame except it does not have the lower mounting lug on the cases in the front. Everything else will pretty much bolt over onto a KZ650 or KZ750 including front end. The rear swing arm was mono shock and also about an inch and a half longer. It has no mounting points for twin shocks. Minor problem. The ZRX 1100 1200 swing arm actually will slide in to the stock frame with the exception of a little shimming. It also is about two inches longer than stock. But you can accept bigger rubber. The front end will also bolt right in with some different sizing on the tapered bearins in the steering neck. The problem now becomes frame twisting with all that moder rubber. The Zr-7 stuff is hard to find. A SV650 front end is identical to the Zephyr and far more easy to find. A lot of racers took the stock front end off for a GSXR front end and have them sitting around.
The ZR-7 motor can be spiffed up by sliding in GPZ pistons and cams. Still available. The Zephyr 550 also benefits greatly from simply putting in GPZ pistons and cams. My wifes Zephyr 550 dynoed at 69 horsepower with this set-up. The pistons slide right in and the cams dropped in. We slotted the cam gears and degreed them up. hope this helps.
The following user(s) said Thank You: JWP993
  • Snakebyte
Re: ZR-7, GPZ, z750
17 Feb 2006 22:34
#24618
Thanks that was helpfull. ;)
  • jordan
  • jordan's Avatar
Re: ZR-7, GPZ, z750
02 Mar 2008 19:23
#198060
hhhmmm! very interesting thread. Do you think zr7 exhaust would bolt up to a kz?
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • Bluemeanie
  • Bluemeanie's Avatar
Re: ZR-7, GPZ, z750
02 Mar 2008 19:32
#198062
The Gringo has a 2002 ZR-7S exaust "bolted" on his KZ650. I believe all he had to do was make muffler bracket?
  • Bluemeanie
Re: ZR-7, GPZ, z750
02 Mar 2008 19:33
#198063
Another angle.
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
Re: ZR-7, GPZ, z750
03 Mar 2008 04:40
#198090
Do you mean like this?
Edit: My bad I didn't see that this thread went on to page 2 and Bluemeanie had already answered. Yes you only need to make a rear muffler bracket and use the shorter style of exhaust inserts used on the 750's other than that it bolts right on. Nice quiet system and being stainless it should last forever. It is heavy as heck though.
Post edited by: The Gringo, at: 2008/03/03 07:46
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • vegasvideo
  • vegasvideo's Avatar
  • "Fat Guys need love too!"
Re: ZR-7, GPZ, z750
03 Mar 2008 23:49
#198273
I actually have a ZR7 motor sitting in my storage. I had it as a backup fr my GPz but sold the Gpz in favor of a ZRX. I wish I had both.
