noises.....
- KZ700A1
1984 KZ700A1
1982 GS550L (the L is for lady!)
Life's a garden.....dig it
- KOOL RYDER
- KZ 650B2 / KZ 1000E
The cam chain tensioner is held on by 2 bolts at the base of the engine under the carbs.
Perhaps you could try tighting up the cam chain before tryig to replace it.
1. Disconnect the neg lead.
2. Remove the points cover
3. Use a 17mm wrench to turn the crank 2 full turns past the 2/3 timing mark and line the corner just past the 2/3 timing mark up with the line through the sight hole.
4. back the tensioner bolt off and then screw it in to set the tension.
Maybe that will help.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- Thank you received: 2098
Perhaps the camchain isn't being tightened quite enough by the automatic tensioner.
If not already tried ---
Engine should be warm, with the crankshaft set at TDC when doing the adjustment. [Edit - see steell's later post that the 1984 KZ700 camchain tensioner is entirely automatic and not like the earlier style which required re-setting the tensioner as part of routine maintenance]
Finding TDC is usually done by setting the crankshaft at top dead center position by aligning the T mark on the timing advancer with the permanent timing mark on the engine case, while turning the 17mm crankshaft "nut" in direction crankshaft turns when engine is running -- don't turn the engine "backward". [Edit -- this method of setting the crankshaft at TDC is applicable to older models of large fours, and and a different procedure may be necessary for the 1984 KZ700]
This TDC position is supposed to allow the most slack at the rear of the timing chain where the tensioner presses against the chain to automatically set the tension while the set bolt is loose before tightening it back up and locking it down with the lock nut. [Edit - see steell's later post that the 1984 KZ700 camchain tensioner is entirely automatic and not like the earlier style which required re-setting the tensioner as part of routine maintenance]
The spring inside the automatic tensioner presses against the cam chain at the designed pressure of the spring, and only removes slack at the rear run of the cam chain where the tensioner presses against the cam chain.
Good Luck!
- MFolks
- Thank you received: 540
Remove the tensioner and check for a binding in the operation of the mechanism or replace it with a mauual one. I think I have seen them at www.kzzone.com , www.z1enterprises, and www.redlinecycle.com
As KZ700-A1 application isn't specifically listed (shows KZ750), would check with Z1E before ordering to assure proper fitment.
APE Tensioner from Z1E
Good Luck!
- KZ700A1
1984 KZ700A1
... What do I have to take apart to find the timing mark and where is the timing advancer?
The "point cover" is the round cover plate which
covers the points or electronic ignition
(such as Dyna-S).
The cover is held on by two screws and is easily removeable. Usually there's a gasket under the cover.
Here's a pic of the KZ900, and yours should be similar.
[click on image to enlarge view]
Will show a pic of the marks to find in a following post.
There is a bolt that screws into the end of the crankcase. Don't touch the bolt.
There is also a larger 17 mm nut for hand turning the crankcase clockwise to enable seeing the timing marks on the advancer unit as the marks come into view.
The marks on the advancer unit will look similar to these.
(Ignore the green circles)
The objective is to align the T mark on the advancer with the permanent mark on the engine case. The permanent mark on the engine case should be easily visible and readily noticed.
All this will be covered much better in your manual when it arrives.
Good Luck!
I've tried to adjust the timing chain tensioner
Perhaps the correct procedure wasn't followed.
- KZ700A1
1984 KZ700A1
Will post a diagram of the 1984 KZ700 tensioner in another post.
Good Luck!
