80 kz750twin Oil filter screw stripped
- toof
- i was born here all my life
toofless dan
santa fe nm
1980 kz750 ltd twin
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- steell
Is the head rounded off, or did you strip the threads?
Since both thread into aluminum, I'll be rather surprised if you stripped the threads on the bolt.
- bountyhunter
- Thank you received: 337
The bolt is steel and the pan is aluminum... guess which part gets most of the damage when that bolt is stripped? I doubt putting in a new bolt would be safe, I think you either need to thread up to a larger size bolt o install some kind of insert. I would drop the pan and fix it right if it was mine. Dropping the pan isn't that hard to do and it gives you a chance to clean off the inch layer of slimy crud that you will find in the bottom of the pan.realized this while trying to tune up ol' Frank. apprehensive to mess with it too much as this increases the damage to the screw. Any suggestions on remedying this mess would be appreciated. also, I could use a new oil filter screw if you might know where one might be... thank you guys
- toof
toofless dan
santa fe nm
1980 kz750 ltd twin
- Thank you received: 2098
[click on image for larger view]
From reading the posts, am thinking the large #23 main bolt is the problem (not the small #19 filter drain screw). But am wondering whether it's simply that the bolt head is rounded off. Or the bolt fails to tighten inside the case and just spins around.
- steell
- Vter Bob
- Thank you received: 4
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- toof
toofless dan
santa fe nm
1980 kz750 ltd twin
the diagram is not the correct schematic. on mine there is a sheild wwith two screws over whatever is underneath them
The earlier diagram is a 1980 KZ750 twin LTD oil filter as shown on the kawasaki.com site.
The following diagram shows the case covers.
Anything look familar?
[click on image to enlarge view]
As Cool Hand Luke might say, "What we have here is a failure to communicate." :laugh:
Good Luck!
- bountyhunter
The shield with two screws covers the adjustment screw for the clutch release assembly.
