Ghaket Leak - What can I use to patch it up?
- KOOL RYDER
- KZ 650B2 / KZ 1000E
A small amount of oil leaks out and ruins the polsh job i did on the bike every time I ride.
Will ghasket silicone work? What do you guys reccomed?
I am assuming that JB Weld is not the answer.
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
- bountyhunter
- Thank you received: 337
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- JR
- Thank you received: 448
Perhaps you could try re torquing bolts although that did'nt work for me.
- RonKZ650
- Thank you received: 240
- KOOL RYDER
I am going to try the silicone route.
I have already spent a ton of money on the bike, i could have just about purchase a 08 GSX-R 750 by now if I add in the shop work , oil filters, ect .... and sooty plugs before I knew I could cleen them and reuse them.....man i have learned a lot from this site.
Anways I am going to clean and smear some silicone on it and wait 24hrs before i ride it and see if it stops the seep.
I plan on:
Painting the bike
Coil Mod
new chain
front and rear sprocket
ss bolt set
new rear spoked rim for B model
stem taper bearings
I have:
New brakes
shims
cam chain
euro racing seat
flasher relays
new turn signal lenses
clubman bars
Brake lever
Tach cable
rear tire
So a little silicone maybe the fix for now.
When I finish off the final bits I am going to post some pics and get rid of that bootylicious babe in my avitar, but until then she is going to keep you guys company until the spring. At least she is sporting Kawaski green.
KR
1978 KZ650B
1979 KZ1000ST
- JR
It may or may not work, but on a KZ650 once I had a leak at the base gasket. Of course it's not the base gasket on a KZ650 but one of the 400 rubber orings. I cleaned the area real good then smeared clear silicon sealer over the area. Kind of ugly and not a real mechanics fix, but it worked for several years. Eventually the clear turned to yellow and the engine needed work that involved removing the cylinder and I fixed it right. I won't disassemble that far for an oil leak.
Thanks for the great tip Ron
Seems to be working for me on the slight seep I was getting at the base gasket under the cam chain tensioner.
I used a thin smear of clear silicone so it is practically unnoticeable. Let it cure for a week while I was away.
- KOOL RYDER
Now I have a problem with the cam chain tensioner. I ordered one from Ape so it is a never ending story with the bike.
Boy does it make some horrific sounds now.
I will be trying to fix the problem before the season ends here in about 5 weeks or so.
Clear silicone, let it cure, no more leak and no reason to tear the engine down.
KR
1978 KZ650B
1979 KZ1000ST
