- Thank you received: 109
Stubborn helicoil
- mark1122
- Keep twisting it
sorry i still dont know what u mean?Mark for your question I meant shouldn't the bolt now have a bigger side to screw into the now tapped hole while the other side of the bolt have a smaller diameter to fit into the small holes in the cam cap?
after u tap and helicoil the holes they are 6mm's again. then u use studs to pull down the cams with the cap,instaed of using the cam bolts to pull down the cam. By useing the studs u have a lot of thread in the hole so u dont strip the holes.
does your coil incertion tool have a slot in the end for the coils tang to fit into?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- APE Jay
- Banned
- Thank you received: 58
Jay
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- harm
- Tom
- Thank you received: 13
The link is from an industrial supplier called MSC, however, Mcmaster carr has them or check your local industrial supply store
www1.mscdirect.com/CGI/NNSRIT?PARTPG=IMLMKD&PMPXNO=2144720
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- kzwolfsr
- Bluemeanie
- Thank you received: 14
- mark1122
- Keep twisting it
if so try a 5/16" heli coil into the same size screwed up hole in a piece of scrap .This may work for u. just check to see if the 5/16" bolt will fit through the cam caps dowel.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
If you have enough material i would use a diiferent style insert so you can stay with the same size bolt. You only need to make sure you have enough material. The insert in this link uses a standard 10mm tap. Once installed the ID thread is 6mm.
I'm not trying to say u are wrong in any way here.
But i would not try to bore the hole to 10mm. the bolt holes are tooooo close the the valve bucket bore holes, and u are at great risk of pushing the metal out or drilling through and causeing the buckets to bind or worse.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- harm
- Tom
So are the outer holes screwed?
But i would not try to bore the hole to 10mm. the bolt holes are tooooo close the the valve bucket bore holes, and u are at great risk of pushing the metal out or drilling through and causing the buckets to bind or worse.
I see what you mean, that is why i said IF there is enough material.
However, a 5/16 helicoil uses a "Q" drill(.332) and the insert i listed uses an 8.8mm(.346) so it is almost the same size. The hole would only be about .007 bigger per side plus then a 6mm bolt could still be used.
Mark you are right in saying there may not be enough room to make either of these work so kzwolfsr make sure you have enough material if you try either of these methods.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- kzwolfsr
