- Thank you received: 16
Stubborn helicoil
- kzwolfsr
29 Jul 2008 05:51 #228858
by kzwolfsr
Original man of the Caribbean
Stubborn helicoil was created by kzwolfsr
I have been putting helicoils in my can cap holes since they are all stripped out only under my number one cap on my 1000. I got the rethreading right but the helicoil goes in at the very begining and stops turning. I burned out like 6 of these things just to get them to screw in and I rethread to make sure it is alright but the coils still jam. What could be wrong here. The threading tool came with the coils so I have the right tap. I wanna ride. O by the way. I got to ride the bike a week ago and the ride went down in disaster.
- Bluemeanie
- Thank you received: 14
29 Jul 2008 06:03 #228859
by Bluemeanie
Replied by Bluemeanie on topic Stubborn helicoil
Are you using the tap that came with the kit? Sure sounds like a thread mismatch to me. I've installed hundreds of helicoils with no problem. Check your tap...
- kzwolfsr
29 Jul 2008 07:02 #228867
by kzwolfsr
Replied by kzwolfsr on topic Stubborn helicoil
yeah its the one that came with the kit
But I have done helicoils before and it was fun untill now. I put the helicoil and the tap side by side to see if the threads will mesh and they are a little off, unless you stretch it or just mash it in alittle. I new this would solve my problem but it was never this hard!
- harm
- Tom
- Thank you received: 13
29 Jul 2008 09:35 #228892
by harm
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
Replied by harm on topic Stubborn helicoil
The tap should be an "STI" tap. So if it is a 6mm thread it should read something like "6.0 x 1.0 STI". STI stands for screw thread inserts. You may try running the tap in the hole again to clean it out.
Tom
Holland, MI
1980 KZ550 ELR
2011 Concours14
2017 KX450 [/color]
- MFolks
- Thank you received: 540
29 Jul 2008 11:33 #228924
by MFolks
Replied by MFolks on topic Stubborn helicoil
Could the Heli-coils themselves be incorrect? Manufacturers make mistakes too and maybe it got missed in quality control or shipping?
- mark1122
- Keep twisting it
- Thank you received: 109
29 Jul 2008 13:53 #228958
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Stubborn helicoil
What does the installer tool look like? Does yours have a slot in the end or a tab?
i have 2 dif brands and 1 gives me headaches.the best 1 has a slot on the end for the coils tang to fit into. u can make 1 by slotting a drill bit.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
29 Jul 2008 13:57 #228961
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
When u install your cams use a longer threaded rod on 2 of the cap bolts.thread the rods in then use nuts to pull the cap down. the cap that pulls the lobe that is faceing toward the valve.
It is easy to stip the bolts on those things.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kzwolfsr
29 Jul 2008 16:55 #228989
by kzwolfsr
ok Fellas. I cleaned the threaded hole a bunch of times and nothing, it just sits there and clicks and threatens to break the tang off if I twist it anymore. The original bolts thread into the helicoil just fine, but the helicoil doesnt thread into the threaded hole. I like your idea Mark, but if I did something like that wouldn't I have to get a bolt that is bigger on one side now? Since I did use a bigger tap? I think I will go get a bolt that will fit the holes and see if the tap is wrong. Anymore suggestions?
- mark1122
- Keep twisting it
29 Jul 2008 19:43 #229036
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
i dont understand what u mean "I like your idea Mark, but if I did something like that wouldn't I have to get a bolt that is bigger on one side now? Since I did use a bigger tap? "
are u saying u tapped the hole to a larger size? my kz 900 uses 6mm. what does yours take and what size did u increase it to?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- APE Jay
- Banned
- Thank you received: 58
29 Jul 2008 22:24 #229057
by APE Jay
Replied by APE Jay on topic Stubborn helicoil
Sure sounds like you are trying to install 1/4-20 coils in a hole tapped for 6 mm.
Jay
Jay
- kzwolfsr
30 Jul 2008 06:08 #229104
by kzwolfsr
the bolts are 6mm. i used a helicoil kit from autozone with insert tool, tap and coils included. The kit was for the 6mm bolts and i even tried it on the bolt before I bought it and it screwd on great. As for the tap or the threads created by the tap in the package, the helicoil nevr screws into the hole. Could there be a possibility of the wrong tap if when I put the threads of the coil and tap side by side and the threads dont mesh without really pushing the coil into the tap? Mark for your question I meant shouldn't the bolt now have a bigger side to screw into the now tapped hole while the other side of the bolt have a smaller diameter to fit into the small holes in the cam cap?
- BSKZ650
30 Jul 2008 06:16 #229106
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Stubborn helicoil
I would go down and get a new set, something is wrong, and its really not your job to figure out what it is, get a new set
