- Thank you received: 1
Fuel Octane, My 2 cents worth, or $4 worth
- tjhiggin
I do run only Chevron or Texaco, both have Techron, to help keep the carbs clean.
T.J. in Huntsville, Alabama
1983 KZ1100-A3, 1974 Honda CB550-4
Previous bikes: CB100, TS125, CB175, KZ400, CB500-4
- xcgates
You guys just made my life more difficult. I'm sitting in a hotel room between days of my MSF class, and was wondering if my friend who said it was imperative that I run high test gas in my '85 Kawi 700 LTD was full of it, and here I find this thread.
His thoughts, which make sense by themselves, is that the engines are high enough compression that they need high test to avoid pre-detonation, knocking, or whatever the technical term is. That, and something about avoiding deposits on the engine internals.
Something to think about while I spend more time on small, dinky, underpowered viberating bikes passing my skills test portion. :woohoo:
- kxhonda
Arrghh!
These kz's are not high compression engines, most are 9-9.5:1. Most the newer sport bikes are mid 12:1 compression. No need for high octane on a stock piston kz.
1977 Kz650B1 #576th made.
Warsaw, In
- KZ700A1
1984 KZ700A1
1982 GS550L (the L is for lady!)
Life's a garden.....dig it
- xcgates
I have an 84' 700 w/ a friend that told me the same thing. I did it for awhile, then on the reccomendation of this board made the change to 87 & never looked back. It's cheaper & runs just as well. Sometimes friends are full of "it".
Its just nice to get a spread of opinions. You know, since nobody in my family likes bikes, or anything other than just driving cars, I like to hear what everyone thinks. So I grew up not knowing a thing about cars. Now I just mess with stuff until it works, I break it, or I actually figure something out. Whether or not I'm right. :laugh:
::EDIT::
Just thought I should add that the sticker says to use fuel with a RON rating of 90. But from what I can tell, RON is normally 8-10 higher than MON, so I figure the pump rating should be something in line with regular.
- Foose
- okay, so im a honda guy......
- Limey
- 3 Years in the U.K. - Brought the KZ with me!
Also remember that lead in gas increases the octane by reducing the propensity to "knock" - so putting in 100LL avgas really does nothing for you, and will cause all sorts of lead deposit problems - don't do it!
The one that always makes me laugh is the stories of guys who put "jet fuel" in their cars/bikes and claim huge performance gains! Trouble is, jet fuel is actually diesel and most spark-igntion engines won't run on it at all!
Eric
Newmarket, England (for 3 years)
Pentwater, Michighan (Home)
1978 KZ650
2000 ZG1000
2006 Suzuki Burgman 650
