Fuel Octane, My 2 cents worth, or $4 worth
23 Jul 2008 12:30 #227870 by srennoc
So this is not a question, rather just a statement. I would like to hear from others what there experiences have been. just for the sake of curiosity.
I have my first bike, a 1980 kz750 twin, and i have been riding it for over a month and have put on a couple thousand miles in that time. LOVIN IT!!!
I had been using the 93 octane fuel thinking that i was going to get better performance from the bike. then here lately i starting thinking that my carbs were getting out of sinc or needed to be cleaned. By chance, I was nearly empty so i just threw in a couple gallons from the tank for my lawnmower (87 octane) and the bike started running better. i ran that tank out and filled up again with 87 octane and the bike is running like a champ.
the bike is basically stock, the only think i can see that has been done is the airbox has been replaced with K&N filters. i am not sure if the carbs have had a jet kit installed or not... but my pocket book is very happy to know my bike runs better on the cheaper gas!
Happy riding!
1980 KZ750G TWIN
23 Jul 2008 12:45 #227872 by supercharged
Replied by supercharged on topic Fuel Octane, My 2 cents worth, or $4 worth
what is the difference in running that you noticed.
The higher the octane the slower the burn, making it cooler and reducing detonation.
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
23 Jul 2008 13:01 #227875 by srennoc
Replied by srennoc on topic Fuel Octane, My 2 cents worth, or $4 worth
I guess the best way to describe it is the smoothness of the engine performance. with the lower octane i seem to have a more steady idle, whereas it was starting to "lag" some. also, even the acceleration and power seems to step up a couple notches. granted, these differences are somewhat slight, however, they are great enough for me to notice and choose to use the 87 instead of 93.
1980 KZ750G TWIN
  • Skyman
23 Jul 2008 13:11 #227878 by Skyman
Replied by Skyman on topic Fuel Octane, My 2 cents worth, or $4 worth
Most stock bikes from that era are designed to run on 87 gas. That's what I use on my '78 KZ1000.
On my '82 KZ1000, I run premium because it has higher compression Wiseco pistions in it.
Unless you've hopped up the engine, regular gas should be fine on a stock bike.
West Linn, OR
23 Jul 2008 13:11 #227879 by ltdrider
Replied by ltdrider on topic Fuel Octane, My 2 cents worth, or $4 worth
I'm no chemical engineer, but the way I understand it, octane level needs to be matched to engine compression.
Low octane fuel burns more easily in the cylinder, and will detonate BEFORE the spark during the compression cycle, IF the compression is high enough. That causes pre-ignition, or pinging.
Natch, this assumes that the engine is tuned and timed correctly.
KZ motors are low compression mills, and are made for regular unleaded fuel, 87 octane.
At current prices, I'm happy to fill up with Regual, and the bike runs fine. I have a 9-mile grade that I have to climb on the way home, and the KZ has always pulled it well, with no pings or knocks.
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
23 Jul 2008 13:44 #227882 by BARNEYHYPHEN
Replied by BARNEYHYPHEN on topic Fuel Octane, My 2 cents worth, or $4 worth
FWIW, my 76 900 runs like crap on anything other than 87.
23 Jul 2008 13:54 #227884 by bountyhunter
Replied by bountyhunter on topic Fuel Octane, My 2 cents worth, or $4 worth
It's a myth that many people believe that higher octane = more energy in the gas.
For ANY engine, here is how you buy gas: keep going down in octane until it pings or runs bad, and then go up in octane until it runs right. Buying higher octane than that is a waste of money.
23 Jul 2008 14:01 - 23 Jul 2008 14:02 #227886 by JohNLA
Replied by JohNLA on topic Fuel Octane, My 2 cents worth, or $4 worth
same here. My 550 loves 87 and hates 93. I read somewhere once that using a higher octane than needed will actually lead to lower mpg. Using that argument, I think I finally convinced my girlfriend to stop putting the expensive stuff in our truck.
s49.photobucket.com/albums/f255/JohNLA_photo/1983%20GPZ%20550/
83 GPZ 550 Stock with 3600 miles_83s.
83 GPZ 550 4-1,pods,Mikuni 36,000 + miles
Last edit: 23 Jul 2008 14:02 by JohNLA.
23 Jul 2008 14:14 #227887 by fixer5000
Replied by fixer5000 on topic Fuel Octane, My 2 cents worth, or $4 worth
my 650 likes 87 a lot more then 91 or 93 octane fuel
1978 kz650b pretty much stock
massachusetts
23 Jul 2008 14:47 #227893 by srennoc
Well i am really glad to hear that so many others have the same experience. i thought maybe it was just a coincidence at first or my imagination, but now that i think about it, even some older vehicles i have had ran better on the 87.
1980 KZ750G TWIN
24 Jul 2008 07:11 #228029 by coppertales
Replied by coppertales on topic Fuel Octane, My 2 cents worth, or $4 worth
I run high test in my KZ1100s in the Texas summer. I run regular in them in the winter...You can broil a steak on the engine while sitting at a stop light here in the summer......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • DoubleDub
  • Visitor
24 Jul 2008 11:30 #228073 by DoubleDub
Replied by DoubleDub on topic Fuel Octane, My 2 cents worth, or $4 worth
A local shop here in Madison has a good writeup on Gasoline including a discussion about Octane.
www.motorcycleperf.com/techtips/gasoline.htm
It's an interesting read if nothing else.
