Still sitting with the 650
- wiredgeorge
You wrote, quote: Every time i have the bike running, and i put it into gear it immediately kicks out. unquote
Trying to understand what is going on seems kind of important. What do you mean by kicks out? Are you talking about jumping out of gear or the bike dying?
- camostriker
BTW, is the bike lurching forward and dying when pushing down on the shift lever to put it into first gear while the cluch lever is squeezed?
that is exactly what is happening. we can move it when it is gear, with the level in. the bike shuts off after jumping forward. i am letting the clutch out slow, but that doesn't matter. tonight i am going to check my compression. eileen is killing me here guys. i just wanna get riding again. taking my friends bikes for a ride is pissing me off. i hate crotch rockets, and cruisers. and i am the only one i know under 35 with a kz. although i keep running into people with kz's in media. damn 250s and 400s. small bikes. what kind of biker gang member am i if my girl don't run.
- wiredgeorge
- camostriker
- Philip Meaney
My 750 Turbo lurches and sometimes stalls when I pop it into first gear when it's cold. Common problem with the turbos (more plates in the clutch). Occasionally, when I really really don't want that clunk and lurch, I start the bike with it already in gear. The dragging is hard on the starter but I've got a spare starter (transmission parts are harder to come by). You may want to try that - at least once or twice. If you can get it running and driving, you may be able to at least figure out if it's a clutch or a transmission problem.
One thing I've noticed is that different motor oils affect my sticky clutch differently. If the problem resides in the clutch, it might be that the plates just don't like the oil you're using.
Another point to consider. I think you said your clutch is new - is it an aftermarket clutch? The Barnett I used to have in my bike was the worst piece of crap ever built - I could idle the bike uphill with the clutch disengaged for the first 20 minutes of every ride.
Couple of simple things to chew on before looking too deep. Hope this helps.
80 750 H1
85 750 Turbo
84 GPz 750
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- camostriker
- mariozappa
- Thank you received: 8
where do those tubes on the bottom of the carbs go?
Those are your overflow hose. They go down between the engine and the swingarm. So, if you carbs overflow the gas will go to the ground and not all over your bike!
1977 KZ650C1
and the KZ650/KZ750 Conversion
- rodneyo
- camostriker
after work today i am putting on a 650 clutch cable and i am readjusting the clutch, then i'll let yous know how it goes.
- camostriker
- MFolks
- Thank you received: 540
1. Loose battery terminals.
2. Green crud on electrical connection terminals.
3. Stator/generator has burned/shorted winding.
4. Rectifier/regulator failing.
I have three websites for stators and regulators/rectifiers:
1. www.rmstators.com
2. www.electrosport.com
3. www.ricksmotorsportselectrics.com
