spare cylinder block
- brianpclarke
20 Jul 2008 17:55 #227333
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
spare cylinder block was created by brianpclarke
I have a 1978 kz650 and replaced the gaskets on it today due to an oil leak. I replaced all the gaskets but against intuition i also replaced the cylinder block with a spare one that i had from a parts bike because it seemed to be in better shape (no broken fins....)
Well got the bike back together and it seems as though i have no compression on cylinders 1 and 2... 3 and 4 look ok though.
Was this a dumb move replacing the cylinder head or do i have another problem which is causing compression issues?
Ran fine before hand... other then the oil leak and i am pretty sure my timing was good....
thanks for all help will be appreciated!
-Brian
1977 KZ650C
1976 Kz900 LTD
- steell
20 Jul 2008 18:54 - 20 Jul 2008 20:05 #227340
by steell
Replied by steell on topic spare cylinder block
You say you replaced the cylinder block, but you then ask if replacing the head was a bad idea.
Replacing block without checking to make sure the bore is within limits and without using new rings after honing is a bad idea.
Replacing one head with another "good" head is usually not a problem.
Which part did you replace?
Last edit: 20 Jul 2008 20:05 by steell.
- brianpclarke
20 Jul 2008 19:11 #227345
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
Replied by brianpclarke on topic spare cylinder block
sorry about the confusion... i replaced the cylinder block from a donor bike.... i guess i will have to go back and switch them back out...
checked compression and I am getting 0... i wouldnt have thought that the bore would have been that far off...
-Brian
1977 KZ650C
1976 Kz900 LTD
- steell
20 Jul 2008 20:04 #227362
by steell
The only way a piston and rings can cause zero compression is if they aren't there, even a piston with no rings will show at least a little compression.
It's still a bad idea to do that though
First the basics.
Throttle held wide open (or carbs removed) during test?
Did you repeat the measurements to make sure that zero was correct?
Are you absolutely certain you installed the cams correctly?
Did you feel a "clunk" in the motor when you first turned it over after reassembly?
It would be a real good idea to put the original block back on the motor, and check for bent valves while you have the head off.
First the basics.
- APE Jay
- Banned
- Thank you received: 58
20 Jul 2008 20:19 #227363
by APE Jay
Replied by APE Jay on topic spare cylinder block
If you have zero, you probably have bent valves. Don't be turning the motor over anymore until you have deone a leakdown test.
Jay
Jay
- brianpclarke
20 Jul 2008 21:34 #227375
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
well... damn.
I have set the timing a couple times and thought i had it on the dot... checked cylinder 1 and got 0 compression.
thought the compression gauge may have been off and checked 4 and got about 120. will do some work tomorrow and try to find the problem...
will follow up as soon as i can... or be calling ape to get some quotes.
-Brian
1977 KZ650C
1976 Kz900 LTD
- wiredgeorge
21 Jul 2008 05:42 #227398
by wiredgeorge
Replied by wiredgeorge on topic spare cylinder block
Steve Elliot wrote... even a piston with no rings will show at least a little compression...
HOW DO YOU KNOW? bwhahahaha
- steell
21 Jul 2008 06:28 #227412
by steell
wiredgeorge wrote:
I used to run a vehicle maintenance shop in the USAF, amazing the things that some of my guys would forget to put in a motor during a rebuild (and some of the tools they would leave inside it). 1/2 rod bearing shell, piston rings, etc, I listened from my office when they would first start a motor after a rebuild, and could usually tell them what parts to look for in their toolboxes that they had left out
- brianpclarke
21 Jul 2008 14:26 - 21 Jul 2008 14:36 #227497
by brianpclarke
-Brian
1977 KZ650C
1976 Kz900 LTD
Well.... pretty good news.
Replaced the cylinder block with the original... and everything looked good physically... cosmetically is another story but..
Got good compression... about 140 across the board but but when i fired her back up i noticed that the exhaust pipe on cylinder 1 wasnt getting hot. I also noticed a rapid clink coming from the valve cover. I have a manual cam chain tensioner and it looks good. Air is coming out of the pipes so... maybe its not firing or could the *clink* be coming from the intake valve?
At least I got her back on her feet.... hopefully i can pinpoint this little matter.
Thanks again guys!
EDIT: checked it again and all the pipes are smoking hot... except 1.. and I have spark ....
Thanks again guys!
-Brian
1977 KZ650C
1976 Kz900 LTD
Last edit: 21 Jul 2008 14:36 by brianpclarke.
- BSKZ650
- Thank you received: 14
21 Jul 2008 14:51 #227498
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic spare cylinder block
have you checke the valves, may need some adj
