- Thank you received: 2
Exhaust Popping
- KYKZ1100
The bike runs well - very strong and idles well, no flat spots, and will pull to redline. The only problem I know of is that the compression is low across the board - all four cylinders are between 105 and 115 pounds, and it uses about a quart of oil every 400 miles.
Any ideas about what to look at next to get rid of the popping?
1981 KZ1100A1 Shaft
2007 BMW R1200R
- supercharged
Beige/brown plugs are ideal.
Dark / black is too rich.
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport......
- Thank you received: 2098
- bountyhunter
- Thank you received: 337
First, I would check valve clearances.
If those are the true (warm) compression readings with adequate valve clearance, the engine needs work.
- KYKZ1100
Bountyhunter - The valves are new (~1,000 miles on them) and all were within specs after they were replaced, but if I can't figure anything else out, I'll check them again.
I checked the compression several times after the valves were redone, both cold without the carbs installed and warm, and the reading were pretty consistent. The highest I saw was cold and one cylinder was 120, the others between 105 and 112 or so. When I put oil in the cylinders, the pressure went up to 145-150 or so on all cylinders.
I bought three NOS 2nd oversize OEM pistons on eBay a month or so ago. If I can find a fourth I'll use those, otherwise I'll look at Wiseco, and I plan to have it bored and put in new pistons and rings this fall. I don't really need more performance and don't really want higher compression so I'd just soon stick with stock.
1981 KZ1100A1 Shaft
2007 BMW R1200R
- bountyhunter
Patton, I'll try that.
So the ring to wall seal isn't holding well.
Smart move, those bikes make plenty of power stock.
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- KYKZ1100
1981 KZ1100A1 Shaft
2007 BMW R1200R
