77 kz650 torqe(ft lbs)
  • djcamp10
  • djcamp10's Avatar Topic Author
03 Jul 2008 07:51
#223717
anyone know how many ft lbs for the bolts under the valve cams?
1977 Kz650 B1
  • anarki650
  • anarki650's Avatar
Re: 77 kz650 torqe(ft lbs)
03 Jul 2008 08:33
#223724
Camshaft cap bolts 8 1/2 according to my clymers.
I think that's what you were asking about.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • djcamp10
03 Jul 2008 08:44
#223726
im refering to the to bolts inside the head under the cams. they appear to support holding the head to the block it's a 10mm bolt. i've already sheared on off and managed to get it out by the grace of all things good and holy. it's part#92002-1881 if that helps.
1977 Kz650 B1
  • steveo_4192003
  • steveo_4192003's Avatar
  • 77kz650b-1
03 Jul 2008 08:48
#223728
this is for the cam cap bolts that hold the cams in place under the valve cover right?
if i remeber right i belive i read on here that most people are setting them a 7 ft lbs! DO NOT over tighten them they will strip out!!
be very,very carful as they strip out very easy.
i am also doing this on my 77kz650b1, and just bought a new torq wrench just for the cam cap bolts so i know they will be accurate (among other parts to). i dont want to have to tap them out to 8mm and all that fun stuff!!!!!
1977 kz650b-1, 4-2exhaust systetm, pod filters ,jetted 112 main, 17.5 pilot
  • OnkelB
  • OnkelB's Avatar
03 Jul 2008 08:53
#223730
The torque spec for the two cylinder head bolts (one under each cam sprocket) is 16 - 20 ft.lbs / 22 - 27 Nm.
Actually they´re 6 mm bolts with 10 mm heads.
77 KZ 650 B1, 82 GPz 1100 B2.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
03 Jul 2008 08:54
#223732
Well that IS a 6 by 43mm bolt,and I'm pretty sure you ARE referring to a cam-cap bolt.
But you say it's "Under the cams" ???
Do you mean that it's under the valve-cover?
1977 KZ1000 A-1
  • RonKZ650
  • RonKZ650's Avatar
03 Jul 2008 08:54
#223733
The bolts below the cams securing the head to the cylinder are 16-20ft/lb according to clymer. I wouldn't personally go that tight on a 6mm bolt myself.
  • djcamp10
03 Jul 2008 08:58
#223735
ronkz650 those are the bolts i'm refering to appreciate the help. i know i should be using the service manual but i ordered one and my severe case of ADD kicked in and gots me hell bent on gettin her back on the road. thanks for the help gentlemen.
1977 Kz650 B1
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
03 Jul 2008 08:58
#223736
THAT much torque on a 6mm bolt??!!:ohmy:
I didn't know the 650 had those 2 bolts there,but wholly...that's a lot of torque for that bolt,no?
1977 KZ1000 A-1
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
03 Jul 2008 09:01
#223738
What HE said!:ohmy:
It wasn't that long ago,that I read here where another member went by the "Clymer" manual,and stripped cam-cap bolts...remember that,Ron?
Make SURE,before torqueing that bolt THAT much...seriously.
1977 KZ1000 A-1
  • djcamp10
03 Jul 2008 09:17
#223741
i just put them down to snug there is know way those bolts were gonna handle that. i just went by feel cause i was startin to get that icky feelin deep down that one more quarter turn and it would be off with the head and out with the drill i can only assume that they are not nearly as crucial as the exposed bolts on the head
1977 Kz650 B1
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
03 Jul 2008 09:17
#223742
On my engine(KZ1000),there are 2 outter 6mm bolts on the head,that thread into the block,and they get torqued to about 7-8 foot pounds,and I would bet my ass that if I torqued them to 16 foot pounds,I'd be strippin em.
1977 KZ1000 A-1
