- Thank you received: 1
KZ400 6-speed in KZ750 twin??
- Becker
- The Doctor Will Rise Again
29 Jun 2008 22:40 #222986
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
KZ400 6-speed in KZ750 twin?? was created by Becker
I have a 79 KZ400 with a 6-speed tranny in it and I was wondering, would that transmission fit into my KZ750B3?? I realize that I would have to change shift drums but would it be a direct bolt in. I know that the overall gearing wouldn't be that much different but it would make for alot of fun. I'm thinking about tearing it down and rebuilding it this winter anyway so i figured as long as I'm there...
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- steell
30 Jun 2008 06:20 #223009
by steell
Replied by steell on topic KZ400 6-speed in KZ750 twin??
After looking at the transmissions on the parts diagrams at kawasaki.com, I don't believe the KZ400 trans will fit the 750 twin.
It does look like the 550 six speed would probably fit the 750 twin though.
- Becker
30 Jun 2008 10:16 #223067
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
Replied by Becker on topic KZ400 6-speed in KZ750 twin??
Wow, I didn't think that the 550 would. I thought that the 550, 650, 750's all shared a platform and that the 400, 440, 750 twin's kind of had a similar platform. Well I guess I'll start looking for a 550 then. Thanks for your help.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- steell
30 Jun 2008 11:00 - 30 Jun 2008 11:07 #223070
by steell
I thought the same thing, but when I started looking at kawasaki.com I noticed that all the 750's (twins and fours except the Turbo) use the same transmission bearings (didn't check all the bearings though), and the 750 twin shares the output shaft with some other models that the 550 output shaft will work in. The output shafts won't share the same part numbers because the 550 uses a different sprocket retention method.
This is based on a cursory search through the part numbers, if I was contemplating installing a 550 trans in a 750 twin, I would certainly do a more detailed comparison.
I believe the 750 four and the 550 output shafts will interchange, I even bought a 550 shaft drive transmission (because they're cheap, no one wants a shaft drive trans) to try it and see if it works. Haven't got a around to it yet though
Last edit: 30 Jun 2008 11:07 by steell.
- Spot
04 Feb 2009 10:09 #262154
by Spot
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
Replied by Spot on topic KZ400 6-speed in KZ750 twin??
Hey Steell!
Did you ever get the 550 shaft tranny workin?
Spot
Spot
- martijn
04 Feb 2009 13:13 #262184
by martijn
Replied by martijn on topic KZ400 6-speed in KZ750 twin??
one of the two shafts does fit of a kz400 (prebike of the 440)but I do not know if it was the drive or clucht..
- pz1morton
06 Feb 2009 08:39 #262531
by pz1morton
1975 Z1 X 2 one i've had since new [many thanks to a great dad whos now since past]i've seen my son eyeing it every now and then.has 1075 kit,yosh cams,yosh pipe,29 smthbrs,rearsets.
1978 KZ650C that i race
1984 GPZ900
1972 CB350 building as another race bike
1982 CB750 w/836 kit,yosh cam
Replied by pz1morton on topic KZ400 6-speed in KZ750 twin??
Out of curiostity what would be the advantage to having the 6 speed trannie in the 750twin.other than it being a 5 speed.more top end? would a kz or gpz550 6 speed trans fit into a 78 kz650c then?if so what years.thanks
Regards Paul
Regards Paul
1984 GPZ900
