Need help with oil/filter change
- Omega
Re: Need help with oil/filter change
01 Sep 2009 19:16
Alright, I got the spring and washer from a Kawasaki dealership and I replaced the filter..
Thanks for the advice!
Omega
1981 KZ750-LTD
Montreal, Quebec, Canada
1981 KZ750-LTD
- DawnKZ750
02 Sep 2009 11:36
No pic of the 750??
1982 KZ750-E
MASSACHUSETTS
MASSACHUSETTS
- fixer5000
02 Sep 2009 11:53
DawnKZ750 wrote:
dawn ...that diagram will apply to yours too
No pic of the 750??
1978 kz650b pretty much stock
massachusetts
massachusetts
02 Sep 2009 13:14
DawnKZ750 wrote: "No pic of the 750??"
DawnKZ750, go to link and click on "Click Here." Ed
1982 KZ750E3 Parts Diagram
- DawnKZ750
03 Sep 2009 12:16
1982 KZ750-E
MASSACHUSETTS
MASSACHUSETTS
- djturnz
13 Jun 2016 15:26
Oh great. I've changed my oil 3 or 4 times at least, and I've always put it back the way it came to me, the cup on the bottom, spring and washer on top of the filter.
What damage have I possibly done?
1982 KZ750 (4) LTD
13 Jun 2016 16:20
I doubt any. The spring keeps the filter snug against the case. You may have let unfiltered oil through if the top holes are exposed.
The following user(s) said Thank You: djturnz
- RonKZ650
13 Jun 2016 18:39
The holes in the bolt are set in a position where it's impossible to really foul up anything by assembling wrong. I believe the main function of the spring is just to keep pressure on the filter to keep it firmly planted. Way they came was spring on the bottom, but if on top no big deal. No little deal even. Even running no spring is no problem. Of course better off always using all the correct parts, but the spring is not all that important.
