Turbo 1000 and high compression
- DaytonaMC
- You keep for your collection, I know you like it.
I must remove my skin.....
- bountyhunter
- Thank you received: 337
You will get more HP by slapping a turbo onto most anything, but getting peak power and reliability means the parts have to be designed to play together.
- APE Jay
- Banned
- Thank you received: 58
- DaytonaMC
So if I run higher compression and, low boost I should be fine?Can't run both. Higher compression and low boost leaves the liner harder and feels great as a street motor. Low compression and high boost is top end power.
- steell
- Makarth
- Thank you received: 1
generally speaking you cant run boost with high compression unless you have the ape heavy duty studs and you're gonna run on a retardedly high octane (race) fuel or you get an uber methanol injection kit. if you go turbo you might as well grab some flat top pistons and get a dyna 2000 system because turbo's require a retard in timing, also cams will be different then n/a engines because valve over lap becomes an enemy to turbo engines. To turbo properly you're looking at alot of work and money that could make a nice 120hp n/a engine and just slap on a wet nitrous kit and a clutch lock-out. Turbos are a novelty unless you're gonna go drag in an unlimited class or you have a megasquirt kit lying around. sorry if it seems like im busten balls i dont mean to come off like that
- PLUMMEN
- Thank you received: 104
- DaytonaMC
you are gonna be limited by a few different factors to how much boost you can run.what exactly has been done to the engine so far?
Well the only thing I have done to the motor is put Wiseco 10.25:1 pistons in and, I have the APE cam chain tensioner. I have Accel coils and, wires and,Dyna S ignition. I also have a custom into 1 exhaust that I made. Jetted carbs and, pod filters. I wanted to turbo it but, maybe I will just put in some cams and, smooth bore carburetors. Any Ideas?
I have also done quit a bit in weight reduction so that helps.
If anyone has an Idea about some nice cams for some good streetable power please let me know. thanks.
- Makarth
- APE Jay
- Banned
- DaytonaMC
couldn't he put a J model head on his bike to lower the compression back down for a turbo?
That is a good idea however, I like the old B model style and, with the way my bike is set up I think it looks better.
I was really stoked about maybe making a turbo'd KZ but, I think I just want naturally aspirated power. If I get some smooth bores or maybe even some flat slide Mikuni's I bet that would help out a bit. Then some new cames and, I think that might be enough for now.
- PLUMMEN
i love Jays responses,simple and to the point!:laugh: ditto on what he said.Yep!!!
