so i guess im going to buy another head
  • cutmesomeslackjk
  • Topic Author
10 Jun 2008 23:46 #219283 by cutmesomeslackjk
so i guess im going to buy another head was created by cutmesomeslackjk
because i have 0 compression across all 4 cylinders (i dont have a compression gauge but i can put my finger over the spark plug hole and turn it over and i can keep my finger there no problem) and part of the head cracked whenever i was putting it back on, all 8 of the holes for the cam caps on the exhaust cam stripped out. so i want a head from a running bike to put on it and also how hard is it to pull the jugs and swap pistons because i would like to put a new set along with new rings in it. and can i 1 cam that is bigger than the other? i was looking at my andrews 2x cams and one of the lobes is wore extremely bad (it is even smaller then a stock cam lobe)
1980 kz 1000
with a 1974 z1 900 on it
electronic ignition from 1980
10 Jun 2008 23:53 #219285 by donthekawguy
Replied by donthekawguy on topic so i guess im going to buy another head
Sounds like you do need a new head. You can find them on ebay pretty cheap or maybe someone has one they will sell you. Any head you get will probably need some work but it's better than a cracked one. :P I have one that needs a spark plug hole fixed and could use a valve job. It's yours if you pay the shipping. As for the jugs they just slide off when you get the head off. You might have to pry on them to get them off. There is a little slot on the bottom of the jugs that you can stick a screwdriver in to help pry them loose. Sounds like the cam is shot. You should be able to buy just one or maybe go with a stock set for a while.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • cutmesomeslackjk
  • Topic Author
11 Jun 2008 00:23 #219293 by cutmesomeslackjk
Replied by cutmesomeslackjk on topic so i guess im going to buy another head
thanks for the offer but i would like to find a head that i can just bolt right on...yeah i figured the cam was shot but do you think i could still use the other cam along with a stock cam?
1980 kz 1000
11 Jun 2008 04:50 #219298 by otakar
Replied by otakar on topic so i guess im going to buy another head
Make sure that the taller cam is on the intake side, but yes the cams do not have to be the same. You can even put an ehost cam on the intake side and an intake cam on the exhost side. You will loose yor tach drive in the process but that is all. Stock Kawasaki cams are ussualy identical with the exwption of the tach drive gear. You can buy a rebuilt head no problem but I would not put a unreferbished head on yor bike you have no idea what the valve seats look like or the valve stems. You can do a lot of work for nothing and it will most likely cost you a LOT more money in the long run. For $300-$400 you can buy a completly referbished head that will be perfect.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
11 Jun 2008 05:23 #219300 by FastKaw1
Replied by FastKaw1 on topic so i guess im going to buy another head
Sounds to me like you have bent valves.
You also can tap the cam caps to 1/4X20 if the holes arrant to bad.
XENU
11 Jun 2008 09:05 #219338 by mtkawboy
Replied by mtkawboy on topic so i guess im going to buy another head
What motor do you need a head for? Maybe I missed it but I dont see it listed
  • cutmesomeslackjk
  • Topic Author
11 Jun 2008 11:46 #219373 by cutmesomeslackjk
thats around what i was planning on spending for one
so i guess im going to sell the system in my car
it is a 1974 z1 900 engine and the head has been completely ported but its junk
1980 kz 1000
11 Jun 2008 12:27 - 11 Jun 2008 12:31 #219377 by bountyhunter
Replied by bountyhunter on topic so i guess im going to buy another head
You can buy a used one from the junkers and get it rebuilt or just buy one already rebuilt. You REALLY don't want to risk dropping one on as is because it will likely give you grief too soon. The valve seals on these KZs don't live real long from my experience, especially if they have been sitting a while.
It's harder than just doing the head. How many miles on the engine? If ot's under maybe 25 - 30k, it probably doesn't need new pots. You can get a micrometer and measure the bore wear when the head is off. The cost for boring alone is probably about $200 and the new set of pots is probably going to be a few hundred unless you luck out on ebay.
Last edit: 11 Jun 2008 12:31 by bountyhunter.
11 Jun 2008 12:28 #219378 by mtkawboy
Ive got a spare 76 KZ900 motor that the head would look original if you cant find one. Its in running condition, couldnt get a title so I parted it out
  • cutmesomeslackjk
  • Topic Author
11 Jun 2008 13:22 #219391 by cutmesomeslackjk
I dont know how many miles the motor has on it because it is a 1974 z1 engine on a 1980 kz frame. but if the gauges were switched out too and i think they might have been the engine has about 20,000 miles on it.....it does not matter to me if the head looks original
1980 kz 1000
  • cutmesomeslackjk
  • Topic Author
11 Jun 2008 16:01 #219418 by cutmesomeslackjk
i did a leak test on the valves and the #1 cylinder exhaust valve dumped water out just as fast as i could put it in but all the other valves held water and when the head was on the bike it felt like i had no compression across all cylinders
1980 kz 1000
11 Jun 2008 18:48 #219468 by mtkawboy
Solvent would be better to use. Did you check to see if you had any valve clearance on the bad cylinder or all of them? Its an expensive job so most people just keep running them until they quit
