so i guess im going to buy another head
  • APE Jay
  • APE Jay's Avatar
Re: so i guess im going to buy another head
11 Jun 2008 20:30
#219504
FastKaw1 wrote:
Sounds to me like you have bent valves.
You also can tap the cam caps to 1/4X20 if the holes arrant to bad.
XENU
People do that, but it is not a good idea. The o.d. of the 6mm bolt is .236" The 1/4-20 is .250". That comes out to only .0075" thread depth on each side. Best to helicoi back to 6mm.
Jay
  • zskunk
  • zskunk's Avatar
12 Jun 2008 13:28
#219661
How much do you want for the head if the other guy doesn't take it. I been needing one for a long time now.
  • Skyman
  • Skyman's Avatar
12 Jun 2008 16:35 - 12 Jun 2008 16:36
#219679
XENU
Jay
I retapped to 8mm bolts on one of my bikes. Seemed to work fine.
On another bike, I used Time-Serts. Those worked well too.
West Linn, OR
Last edit: 12 Jun 2008 16:36 by Skyman.
  • cutmesomeslackjk
  • cutmesomeslackjk's Avatar Topic Author
12 Jun 2008 19:45
#219698
all of the valves were good....and i almost know i got the bike back into time....i put the arrow on the exhaust cam level with the head facing ford and counted 28 pins back and lined the 28 mark on the intake cam up with it...i dont want to fool with tapping anymore holes out i want to buy a head that all the threads are good on or have already been tapped /helicoiled
also here is a pic of the cams i almost used
1980 kz 1000
with a 1974 z1 900 on it
electronic ignition from 1980
