starting after 10 years-...........she is alive !!!!!!!!!!!!!
  • School Teacher
  • School Teacher's Avatar Topic Author
27 May 2008 22:21 - 04 Jun 2008 10:17
#216324
ok i bought a kz1000 g that had been sitting for ten yrs yes the gas smells GREAT! any way im going through the fuel system (have some carbs if all else fails) so i know i gotta get that going but is there any thing i should do for the engine it self, other than changing the oil?take the pan off? give me advice with the thought in mind that i am actually building "my bike" as well(a 76). this has chrome that is peeling off for days. looks uggy on the outside(Has 25k on it) and i wanna run it asap but not irresponsibly.
any thing i need to look out for? got it for 150$ and has an unscratched kerker in decent shape on it so can't go wrong eh.
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
Last edit: 04 Jun 2008 10:17 by School Teacher.
  • donthekawguy
  • donthekawguy's Avatar
Re: starting after 10 years
27 May 2008 23:18
#216328
If you just want to get it to run to see if it runs, you might want to take the carbs off and spray them out a little, take the plugs out and put a few drops of oil in each cylinder and crank it over a bit. Then put the plugs in and fire it up. These bikes recover from sitting for long periods better than probably any bike. It will run like S but it will run. Then you can get into the carbs and electrical.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • steell
  • steell's Avatar
28 May 2008 06:28
#216350
It's not clear (to me anyway), but if the bike has the original fuel injection system on it, then I would dump some fresh gas mixed with Fuel Injection Cleaner in the tank and run it.
That's after doing the new battery, oil change, tires, chain, and etc stuff.
After I got it started I'd check the valve clearances, just because it's probably never been done.
  • School Teacher
28 May 2008 12:48
#216421
any thing else? and it does have fuel injection (im starting with that and the tank). thanks for everything so far
1980 kz1000G1
  • donthekawguy
28 May 2008 23:15
#216539
Woops fuel injection. :blush:
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
  • School Teacher
03 Jun 2008 23:00
#217792
ok so i went through replacing hose and gas. battery etc. any way cleaned it up and in aabout three seconds of cranking it started! wasn't expecting that! thought a few pops and bangs first but it didn't started right up. tons of carbon came out then i shut er down after a few seconds and called my friend (took longer to start it on the phone this time of course) but it started. reved high found an intake leak. that helped but the fast idle is frozen so im working on that. 150 bones and i got a bike that should work. She ain't pretty but she'll work yahoo!
1980 kz1000G1
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
04 Jun 2008 11:00
#217866
congrat on the startup.it's always a good feeling when they first start back up.
  • BSKZ650
  • BSKZ650's Avatar
04 Jun 2008 11:18
#217870
Way cool,, another bike brought back to life
77 ltd1000, current rider
76 kz900, just waiting
  • School Teacher
06 Jun 2008 11:32
#218367
thanks she is starting to run better and better im working out the kinks.
1980 kz1000G1
