- Thank you received: 1
Teflon Wrist Pin Buttons
- Maverick
Cheers!
1981 KZ1000M1
- wireman
- Visitor
- Maverick
1981 KZ1000M1
- z1rkrazy
- Jeff.Saunders
It seems like many racers now use the spiral lock circlips rather than the buttons. Although I can tell you the spiral circlips are a pain to remove.
www.z1enterprises.com
Z1 Ent on Facebook,
- wiredgeorge
- z19OO
- Thank you received: 3
1975 z1 900
1979 kz650b
- MDawnz1
- Thank you received: 27
Use ONLY what comes with your piston kit!
The pistons/pins/clips come as a matched set and work together as a set.
If they come with wire keepers use them ONLY .
If they come with spirolocks use them ONLY .
They are NOT interchangable .
And wrist pin buttons are just that , they fit in the pins NOT the pistons (tapered pins)and are for SHORT term EXTREME uses ie VERY highly mantained engines.
1974 Z1a, still 903
- APE Jay
- Banned
- Thank you received: 58
OK , here is the lowdown on this subject,IF you want your engine to live a long and happy life.(And dont we all)
Teflon buttons fit in the piston bore, not the pin itself. They work fine in long term application. Regardless of what came with your pistons, you can safely use teflon bittons instead. The only exception to this is some of the newer forging designs use a real short pin and the pin bpres in the piston are not out ar the cylinder wall as the old style pistons ( sull skirt). With those styles you have to use the supplied clips.
Jay
- Maverick
Cheers,
Maverick
1981 KZ1000M1
- KawasakiJockey
- Kawasakikid
