- Thank you received: 14
Engine Knock On Start Up? Whats Cuasing this..
- Bluemeanie
- Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- bountyhunter
- Thank you received: 337
Well. I put 20w50 in her. The first start up was brutal noise wise. But it imediatly went away. I dont think it has done it agian since then. No gas smell in the old oil either. No loss of power since Ive notiched this going on. Im at a loss to what is casing it. Oh my freind brought up a good point. What octane rating are these bikes suppose to use? Also this noise is the valve furthest away from the ground when its on the side stand so maybe it just because the oil runs away...
A valve or lifter usually makes a "click" or "tick" kind of noise. The only thing I have heard knock is a worn rod bearing.
- Bullitt03737
- Makarth
- bountyhunter
Going to thicker oil usually doesn't help, it still takes time for the pump to get pressure up. Thicker oil helps if things start knocking when the engine gets really hot, not a cold start noise.
You might try some STP oil treatment or Rislone as they tend to stick in places better and might quiet it down a little.
- Thank you received: 2098
... 81 Csr...Ian
Thinking this bike is the same 1981 CSR 1000 mentioned in an earlier thread. With rods turning in needle bearings on the crank with 3 lbs or less oil pressure, same as the Z1 and KZ900.
- Bullitt03737
Theres me Ian and another that I know of. I pulled the carbs last night cuase it started leaking gas back through #3. But the carbs were fine except when I pulled the plugs out of the pilot jet circuits there was another plug of rust behind it. Crazy. And the others had residue. Its a miracle it was running in the first place! But I cleaned that out and it idles much better now. Its the petcock that dosent work and it dosent shut off, and forced fuel in the bowls. The valves just seem abnormaly loud to me compared to our police crusiser kz. The valve cover gasket leaks something feirce. Is that common occurance in these bikes?
Old hard worn-out leaking valve cover gasket should be replaced with a new one.
Noise from camchain is often quieted by synching the carbs. And also attending to the other tuning items, such as assuring correct valve clearances, ignition timing, new sparkplugs, etc., all toward a smoother running better performing engine.
Petcock only allows gravity fuel flow to the carbs, and doesn't force the flow. Where fuel is coming out the floatbowl overflows, it's often because the float needle tip is failing to fully seal the orifice in its seat (usually resulting from crud or grit at the interface).
Good Luck!
- bountyhunter
Not really, unless somebody warped the cover prying it off or chewed up the edge scraping the gasket off. Even if your cover is chewed up, you can seal it up tight with black RTV gasket sealer if the leak is a chronic problem.The valve cover gasket leaks something feirce. Is that common occurance in these bikes?
- bountyhunter
Bullitt03737 wrote:
Yep, been there. The needle tip is a metal-to-metal seal against the brass seat. Take the needles out and chuck them in a hand drill and spin low speed and polish the tip with #600 paper until dead smooth and shiny. Use a Q-tip and chrome polish to polish the inside of the brass seat until smooth and shiny.Where fuel is coming out the floatbowl overflows, it's often because the float needle tip is failing to fully seal the orifice in its seat (usually resulting from crud or grit at the interface).
Good Luck!
If tyhere is any roughness or burrs at the junction between the tip and the seat, it will leak like a fire hose.
- Bullitt03737
