- Thank you received: 2098
Engine Knock On Start Up? Whats Cuasing this..
...oil was seeping up past the outermost valve cover bolt. Its like its getting hot and "boiling" out. Is there anyway pressure could build up inside? Ehh. Ill probaly just ride it and wait for it to blow up. I dunno. I dont want this to turn into a money pit!
Am thinking the new valve cover gasket will resolve the leaking issues.
Although tedious, should carefully and painstakingly remove all traces of old gasket from both mating surfaces and without damaging either mating surface, and avoid leaving any remnants or traces of the old gasket behind inside where they may possibly obstruct oil passages. This is sometimes the most time consumming phase of the job when replacing the valve cover gasket.
Should not need any sealant on either side of the new gasket. Just replace it dry.
May be okay to re-use the end plugs. When reassembling, may sparingly use a little silicone sealer on the end plugs. Be careful none of the silicone can ooze out into the inside, because excess can break away and obstruct oil passages.
At normal operating temperatures, the valve cover is expected to be way too hot to touch, even when riding in cold weather.
Is an accessory oil cooler being used?
Good Luck!
Click here > Z1E Gasket
Good Luck!
[Click on image for larger view]
- Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- bountyhunter
- Thank you received: 337
I have a new gasket coming. //// I dont want this to turn into a money pit!
I hear you, OEM cover gaskets for my twin are expensive. I make them out of gasketr material from Pep Boys. Takes about 45 minutes, saves me about $20. Work great.
- Bullitt03737
- bountyhunter
Thats an excellent idea to make your own gaskets. Ill have to make a "master" to copy from.
The cheapskate way..... speak from experience.... is to use the cover to draw the outside outline then use the remnants of the old gasket to do the inside lines and holes.
- Bullitt03737
- bountyhunter
cam, lifter, cam chain.The noise becomes a consistant tick after it warms up. What do you guys make of this?
Valve clearances spot on?
- Z1R rider
- Thank you received: 5
1978 KZ1000, Z1R
1999 250 Ninja race bike
2013 WR250F, fun in the dirt
- Bullitt03737
- Bullitt03737
- PFC FNG
- I've got the sickness!!!
I know it would not be any fun if it was easy, but does it have to be this much fun?
84 ZX750 GPZ (Waiting for paint)
Eastpoint, Mi
