- Thank you received: 1
Crank won't turn
- RedneckSamurai
16 May 2008 19:00 - 16 May 2008 19:10 #214108
by RedneckSamurai
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
Crank won't turn was created by RedneckSamurai
Well long story short, on my '76 900ltd I pulled my head to have some work done and decided to pull jugs to have them cleaned and painted. Well I went to put jugs back on and found that the crank will only turn 45degrees, for that distance it turns freely then stops with a clunk that sounds like its coming from the rotor side. Well I'm at a loss so any ideas welcome...I really don't want to split the case:(
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
Last edit: 16 May 2008 19:10 by RedneckSamurai.
- Thank you received: 797
16 May 2008 19:57 #214115
by 531blackbanshee
Replied by 531blackbanshee on topic Crank won't turn
might cost you some gaskets but you could pull the alt.cover and make sure that there is not anything (screw)in there getting jammed up in there.it is possible to see almost all of the crank by pulling the ign and alt covers and dropping the pan.i would start by pulling the alternator cover,if you are careful you might be able to reuse the gasket with a lite dressing of sealer.my02fwiw
- RedneckSamurai
16 May 2008 20:08 #214120
by RedneckSamurai
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
Replied by RedneckSamurai on topic Crank won't turn
Well I guess I won't have to buy a new oil drain plug.... I let my friend and his 4 year old boy hang out an "help" for a bit and guess what I found. Yup the magnetic oil drain plug wedged under the crank. Gotta have the 4 year old keep a better eye on my Buddy stop him from putting cool things in places they shouldn't
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
- Sandy
- Fly High,Tony
- Thank you received: 13
18 May 2008 10:32 #214348
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Crank won't turn
So did it do any damage?
Did you get the crank to turn over completely?
Wow...whoda thunk it,eh...a magnetic drain-plug?
I'm assuming it WAS the magnetic piece that came apart,and stuck to the crank?:ohmy:
1977 KZ1000 A-1
- RedneckSamurai
18 May 2008 17:45 #214430
by RedneckSamurai
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
Nope someone dropped the whole plug in and it was stuck to bottom of the crank under #1. I tried turning it by hand and never forced it so there was no damage. Stangest thing I've ever found in a crankcase.
1977 KZ650
1976 KZ900ltd
1976 KZ900 A4
- Sandy
- Fly High,Tony
19 May 2008 08:25 #214530
by Sandy
1977 KZ1000 A-1
The WHOLE PLUG?!!:ohmy:
How in the HELL?:blink: ...awww,nevermind,lol.
Some people should really just stick to sewing-machines!
1977 KZ1000 A-1
