My Ongoing '78 KZ1000 LTD Project - Engine Thread (Lots of Disassembly Pics)
- Beatpoet
I called the local Kaw guy today.. He theorised that:
1) The old points were so bad you had weak ignition.. Someone probably tuned it into the ground rather than replacing parts. I'd tend to agree, judging by the fact that someone would rather cut the chain short than replace it.
2) The stock jets (#105) might be too small for the 4:1 Jardine with no baffle and free-flow K&N paper intakes..
So I had a set of #115 Jets laying around.. I also trimmed each idle mixture screw 1/2 turn counter-clockwise.
The plugs are still white, but much less so... The thing moves like a bat-outta-hell now... But due to the badly clearanced valve on #1 (I think) and the new, richer mixture #1 doesn't fire at idle anymore, only at medium throttle.
I found a short in the plug caps for both #1 and #4 (you move them and you get 'Open Loop' resistance on the meter) but #4 still fires OK...
Next step: Valve Job.
If one plug cap was bad, would the timing be thrown off causing hotter running?
- Thank you received: 2098
...stock jets (#105) might be too small for the 4:1 Jardine with no baffle and free-flow K&N paper intakes..set of #115 Jets laying around...trimmed each idle mixture screw 1/2 turn counter-clockwise...plugs are still white, but much less so...due to the badly clearanced valve on #1 (I think) and the new, richer mixture #1 doesn't fire at idle anymore, only at medium throttle. I found a short in the plug caps for both #1 and #4 (you move them and you get 'Open Loop' resistance on the meter) but #4 still fires OK...Next step: Valve Job...If one plug cap was bad, would the timing be thrown off causing hotter running? [/b]
Larger main jet may be preferable with freer flowing intake and exhaust, but will have most effect at wide open throttle where it determines the fuel mixture.
Pilot mixture screws are usually set where they most enhance idle.
Using a thinner shim to increase clearance in #1 intake valve should avoid any loss of compression at normal operating temperature.
Would not expect a faulty plug cap to affect ignition timing or contribute to overheating.
The hard truth is that until air leaks, #1 intake valve clearance, and any remaining ignition faults are corrected, carb adjustments are futile and often counter-productive.
Good Luck!
- Beatpoet
As Uncle Dan says:
So what happens if there is too little clearance? Well, for one thing the valve loses most of it's heat through the valve seat. If the valve doesn't seat fully it will start to get hotter and hotter. Sooner or later the valve starts to melt or burn. Not good!
Am thinking #1 intake valve has not yet suffered any damage, especially since compression tested okay.
- Beatpoet
- Beatpoet
- Beatpoet
- Beatpoet
...It turns out that I have burned the rings down in cylinder 1 after a compression test.
I guess it didn't pay to not fix immediately.. Running cylinder one with an intake valve hanging is going to merit a re-hone and new rings.
Well... Pics of total disassembly coming soon.
...burned the rings down in cylinder 1 after a compression test... Running cylinder one with an intake valve hanging is going to merit a re-hone and new rings....
IMO the overheating more likely resulted from excessively lean mixture created by outside air leaking through old cracked worn-out carb-holders, which aren't repairable with silicone or anything else, and regardless of being glued to the head when installed.
Good Luck!
- Beatpoet
The old rubber is not in that bad of a condition, it was really dirty and oily though. once I cleaned them up they looked and flexed like new.
As I am on a rock-bottom budget, I'll be riding these ones for a little while anyway.
After all, I'm going to pay someone else (read: more experience) to mic and bore/hone the cylinders and pick my new rings.
Good Luck!
Z1E Carb Holders
Would like to assure the over-heating issue has been resolved before risking damage to the fresh new engine work.
Good Luck!
- Beatpoet
