Online microfiche
- po boy
Online microfiche
06 May 2008 18:39
Anybody have a link to some online microfiche for a 1980 KZ750E1 that list the factory part numbers (unlike Bike Bandits proprietary numbers). Neither Ron Ayers or MR Cycles has the KZs on their sites.
1980 KZ750E1
2002 Hayabusa
2002 Hayabusa
- The Milkman
Re: Online microfiche
06 May 2008 18:44
Have you tried buykawasaki.com? It's a little convuluted getting to the parts area but start by cursoring over "owers info" and then select parts diagrams. Then enter the info for you bike,, it well get you there.
- rstnick
06 May 2008 18:49
Go to
Kawasaki parts dia.
and click on "owner info - parts diagrams".
Then on "continue" behind motorcycle.
Then choose your year, engine size and "all" and "all" + "continue".
Then "click to choose" for your model.
Then "parts diagrams".
And then choose which diagram you want.
On the later screens when you are looking at a particular part, you'll see a yellow question mark circle. If you click on the ?, it will show you what other models use the same part.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- po boy
06 May 2008 18:53
I tried buykawasaki a couple days ago, but they didn't list my bike at all that I could find.
I'll go check again.
1980 KZ750E1
2002 Hayabusa
2002 Hayabusa
- steell
06 May 2008 19:00
I'll let you in on the secret, Kawasaki lists the 80-82 750 fours as "740 cc"
Don't tell anyone that I told you though.
- po boy
06 May 2008 19:16
Had to go to the E3 (1982) model to find my parts.
Thanks guys.
Just wish their site was more dial-up friendly.
Takes 5 minutes for each page to open for me over there....
Thanks guys.
1980 KZ750E1
2002 Hayabusa
2002 Hayabusa
- oldcoldankles
06 May 2008 19:41
Click on the following link for parts for your bike as well as part prices:
www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- po boy
06 May 2008 21:47
oldcoldankles wrote:
WOW! That's some of the best online microfiche I've run across.
Thanks very much.
Ron Ayers had much better prices, once you get the part numbers.
www.ronayers.com
Thanks very much.
www.ronayers.com
1980 KZ750E1
2002 Hayabusa
2002 Hayabusa
- steell
07 May 2008 05:14
And Z1 Enterprises
www.z1enterprises.com/
has beat Ron Ayers prices every time that I have compared the two.
You just have to contact Z1 and give them the part number, since they don't list all the parts on their website.
Ron Ayers and Z1 (along with everyone else) gets their OEM parts from the same places, Z1 just has a smaller markup
I used to order from Ron Ayers, until I discovered that Z1 could get the same parts for less.
- JR
07 May 2008 06:15
steell wrote:
Or here's another secret. Select 705cc and for the year select 82. Then Select Standard 750-4. That will bring up the E1 E2 and E3
- po boy
07 May 2008 08:18
steell wrote:
I'll give 'em a chance. Ron Ayers is so cheap, I wouldn't think Z1 could afford that small a markup.
And not all dealers are charged the same. The more parts you sell, the cheaper your wholesale cost. Ron Ayers sells more than anybody else.
And Z1 want's almost 4 bucks for a NGK spark plug cap. I can get the same thing for less than that locally, and under $2 elsewhere online.
Not knocking Z1 necessarrily, I've got a bunch of carb parts coming. I'd like to see them be low man on O.E.M. parts.
And Z1 Enterprises www.z1enterprises.com/ has beat Ron Ayers prices every time that I have compared the two.
1980 KZ750E1
2002 Hayabusa
2002 Hayabusa
- JMKZHI
Last edit: 04 Dec 2008 06:30 by JMKZHI.
