GPz750 cylinder install
- murphus
Thanks, Richard
- bountyhunter
- Thank you received: 337
I haven't done a four, but the approach I would us is do the middle pots first with them up a little higher than the outers. Put the piston supports under middle ones and clamp the rings. Lower the cylinder slowly and get it just started over the first ring. Tap down slowly adjusting the clamp pressure as needed. Remove the clamps and piston holders. Rotate the crank raising the pots already in and the cylinder will raise with them. Get the outers high enough to get the supports under them and apply the clamps. Tap the cylinder down onto them and then remove the clamps and supports.
Some things I learned:
1) Use fine sandpaper and polish the inside of the clamp bands to maki the things slide easier.
2) Use plenty of oil on them.
3) Oil rings break REALLY EASILY....
4) Draft an assistant to help because you are trying to support and guide the cylinder down, wrangle the pistons and clamps and also adjust the clamp pressure just right.
5) if the clamps are too tight, they will not let the cylinder down. Too loose,a dnthe cylinder will hang on the edge of the ring.
6) tap lightly, go slowly, and keep checking to make sure a ring has not popped out of the clamp and is blocking the cylinder.
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
I am not sure this would be easier, I think fighting two at a time is hard enough.....
- bountyhunter
- murphus
Richard
- Mcdroid
- Gone Kwackers
Somebody has suggested using large hose clamps are ring compressors. I have not tried it, but they are cheap enough you could buy four if you wanted to.
They are, in fact, exceptionally cheap, and I have tried this technique...it sounded incredibly simple when suggested to me..I went back to my two-fisted approach as the design of the hose clamps doesn't permit the leading edge of the sleeve to cover the compressed rings without bumping into the hose clamp...the Kawasaki ring compressors have the clamp offset to allow the sleeve to slide over the rings:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- guitargeek
- Thank you received: 50
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- bountyhunter
That's the best design. I ended up with the standard kind with a straight band. Harder to use, you have to get the tension just right to hold the ring enough to let the cylinder slip down and not clamp too tight. I popped a ring on the second rebuild, not sure how.
BTW: you may want to file a little bit on the "bevel" at the base of the cylinder to help it get over the edge of the ring.
- bountyhunter
Good one. I thought of that and couldn't do it. The tolerance fit of the wrist pins to the rods and pistons on mine is so tight I couldn't get them to line up that way.... in fact, it was hard to get the pins through without the cylinder! The pins were a press fit, zero tolerance at all.When I was putting together my buddy's Spectre, I removed the pistons from the rods, used one ring compressor tool to slip the pistons into the sleeves, rotated the crank until 2 & 3 were up, installed the wrist pin & retainers, then rotated the block until I could so the same 1 & 4. Yes, it's tricky and I took me two tries to get it, but it worked. It helps to have some short pieces of 2x4 to use as props to hold the block at the right height.
- Qdude
- It is all good.
- Thank you received: 1
77 KZ 650 C1.
77 KZ 650 C1.
- bountyhunter
I don't think so. The piston to cylinder clearance is only a couple of thousandths.Couldnt you use cut aluminum from pop cans to fashion a sleeve out of that would be thin enough to go into the jug with the piston? Then be removed once the rings clear the edge? maybe with the help of a hose clamp?
