GPz750 cylinder install
  • steell
  • steell's Avatar
Re: GPz750 cylinder install
27 Apr 2008 07:00
#209428
bountyhunter wrote:
Qdude wrote:
Couldnt you use cut aluminum from pop cans to fashion a sleeve out of that would be thin enough to go into the jug with the piston? Then be removed once the rings clear the edge? maybe with the help of a hose clamp?
I don't think so. The piston to cylinder clearance is only a couple of thousandths.
.0015" IIRC, I have a roll of .001" steel, it can be crumpled in your hand like aluminum foil :)
