accidental overrev, low compression, apart she comes!
- sheik*yerbouti
Idle was low at the next light and my Acewell gauge telltale page showed 12,200rpm! Also hear a slight tap tap tap from the right side of the motor.
I limped and low RPM'd home to the shop. Pulled the plugs and pinned the throttle and did a compression test, going left to right from #1 - 105, 100, 20, 105. So I definately floated the valves and bent them up in #3, and may have nicked them all - was expecting 150+, won't know till I get it apart...
2400 miles into my freshly built big bore cammed cafe racer, and finally having solved some charging and electrical gremlins. Oh well, nothing money and time can't fix!
I will report back and show some pics of the carnage!
Definately have a Dynatek coil-cut rev-limiter on the shopping list so we don't have to do this particular dance ever again - at least for this reason!
She's on the Pit Bull stands for the forseeable, at least we have a rainy and cooler weekend on tap so I can get her apart...
I am beginning to think it doesn't like me! Shame, oh well time to get busy. At least I've got 3 other bikes in tip top so I'm not wasting a beautiful Spring!
- PLUMMEN
- Thank you received: 104
- Qdude
- It is all good.
I was with the thread that documented your electrical problems, and was glad that it seemed to be ironed out.
Hope it is an easy fix bro'.
77 KZ 650 C1.
77 KZ 650 C1.
- bountyhunter
- Thank you received: 337
I had a similar disappointment when I did a rebuild on my 750.... and about 100 miles after (running perfect) the cylinder base gasket started to disintegrate. In a couple of weeks, it failed bad enough that the cylinder shifted enough to knock the compression down to 20 psi in both holes.
had to taer the whole thing down to the rods again.... and managed to snap a piston ring going back together the second time.
But eventually I got it all fixed up and it runs like a Swiss watch now.
hang in there..... you can beat it as long as you keep fighting.
I can hardly see the tear stains on my keyboard now.:laugh:
- OKC_Kent
- Thank you received: 20
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- APE Jay
- Banned
- Thank you received: 58
- bountyhunter
That never needs to happen again.
kzzone.com/igpage3.html
Scroll down.
Jay
They been putting rev limiters on race engines for years....
Not to mention, I think they put them on new cars. When I got my new Chevy Cavalier Z-24, I wasn't used to the engine. It is an FI 2.4L 160HP engine that pulls REALLY strong to redline and always sounds like its revving a lot less than it is.
A couple of times I stood on it in first gear to get up to expressway speed and felt the engine cut off for an instant then come back on just before I shifted. I noticed I was hitting red line.....
I'll bet they have a computer chip in there recording all that for when you need engine work under warranty and they are going to say NO.....:laugh:
- Ituen
- Rider
1982 KZ750 E
Kawasaki Rider
- vach
1979 kz650 B. Chicago, Illinois
- steell
That sucks!! Is there a rev limiter for motorcycles? (I don't want to over rev my motor).
Click on the link in APE Jay's post
- kawsakiman
- Thank you received: 6
I'll bet they have a computer chip in there recording all that for when you need engine work under warranty and they are going to say NO.....:laugh:[/quote]
you can pull info from cars.
when i worked at saturn a young kid's car was towed in with the engine locked.
same story, i was just cruising at 60mph when she just quit.
i hooked up the tech 2 and read the freeze frame data.
he changed his story when i showed him that his car told me he was going 83mph, in third gear with the engine turning 7800 rpm's.
a rev limiter is a great idea.
i install them on my bikes just for that reason.
cheap insurance after an expensive build.
- 79MKII
- Love Them Kaws!
- Thank you received: 43
Hope things go well on the re-rebuild.
The Kaw List:
