kz 650 oil temp
- brianpclarke
I read some forums where the proper temps should be between 160 - 210.... and was wondering if this is normal.... and should I be concerned ... and what is considered overheating??
Thanks....
Brian Clarke
1978 Kz650C stock except pods
oil thermostat a sunpro running out of the oil pan
-Brian
1977 KZ650C
1976 Kz900 LTD
- BohicaBob
- Thank you received: 35
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- steell
The normal operating temp for oil is generally considered to be 210-220 degrees F, 250 for an extended time is pushing it.
- cafekz750
1981 KZ750H2 - V&H 4-1 pipe, pods, jetted, clubmans, homebrew rearsets, 18" rear wheel and more.
Parting out a 1982 KZ750H3 to fund future projects
2 other non-Kawasaki motorcycles
- MCH650SR
Were you concerned about the oil temp before the gauge install?
I have a temp gauge (water cooled) on my Honda CX500 and I hate it. I'm constantly monitoring it; taking away from a stress free ride. Everytime the temp gauge goes up a bit, I'm fearful it's starting to overheat.
Now I drive my SR650 and it feels great. No gauges to vex me. 'Who needs those stinkin' gauges?!'
1979 KZ650SR
modified with BS32 carbs
Yoshimura 4 in1
2006 Kawasaki Sherpa
1979 Honda CX500
BC Canada
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BSKZ650
and most were saying the normal temp range should be 220-230 degrees.
- bountyhunter
- Thank you received: 337
anyone know what temp oil starts to brake down?
Depends. Synthetics hang together better than dino oil when getting temped up. That's one of the reasons syns are better.
www.pelicanparts.com/bmw/techarticles/Bo...lt_synthetic_faq.htmSynthetic oils were originally developed more than 50 years ago and became widely used in jet engines. Less than -120ºF ambient temperatures, 60000 shaft rpm, and 500º+F exhaust temperatures proved too much for conventional oils. Synthetics were created specifically to withstand these harsh conditions and to date every jet engine in the world uses synthetic lubricants.
At the other end of the temperature spectrum, high engine temperatures and heavy loads (as typically found in towing or racetrack applications) cause these chains to break down and the base stock actually boils off causing a change of viscosity and the formulation of sludge. This can happen at temperatures as low as 230º F and by 250º F many petroleum oils are suffering significant breakdown. Synthetic oils on the other hand are engineered specifically to provide all the lubricating properties that natural oil possesses, but none of the cold thickening or hot thinning properties of petroleum oil. Synthetics are made up of uniformly shaped molecules with shorter carbon chains which are much more resistant to heat and stress. Synthetics can withstand temperatures of 300ºF all day long and still protect your engine. In fact the American Society of Testing Materials (ASTM) standard wear resistance tests are conducted at 302º F. In this test synthetic lubricants far out perform petroleum lubricants by factor of four to one and greater.
