- Thank you received: 1
GPz1100 Cams--Which one is intake/which is exhaust?
- Rickman
26 Mar 2008 21:16 #202407
by Rickman
1983 KZ1100-L1 "LTD Shaft"
Wiseco 10.5:1 1171 piston kit, bored by APE
Dyna 2000, Dyna S, Dyna grey coils, WG coil power mod, CB900 starter
Replied by Rickman on topic GPz1100 Cams--Which one is intake/which is exhaust?
Skyman wrote:
From what I understand reading posts around here - the slotted bolt holes on the adjustable sprockets are so you can get a degree wheel and a pointer and degree in the cams so they are 100.00% perfectly aligned, to allow for the precisest ignition timing.
FloridaBiker wrote:
At this point I highly suggest getting the adjustable gears.
Why? What would adjustable gears do for me? I assume I could get those from APE?
- tuxedotito
28 Mar 2008 19:05 #202806
by tuxedotito
1981 GPz1100, Wiseco 1170 Kit, BS34 carbs; #40 Pilot and #140 Main, UNI Filters, APE main and cylinder studs, DYNA S, DYNA Coils, and lots of hours. Working towards Megasquirt/Turbo one day!!!
Ft. Lauderdale, FL
Replied by tuxedotito on topic GPz1100 Cams--Which one is intake/which is exhaust?
Thanks...and glad to do it. It might help someone else sometime, who can say?
I have a full day planned tomorrow in my uncle's garage with a flea-bay front rim in nice conditon, ready to
beadblast!!
beadblast!!
Ft. Lauderdale, FL
- PLUMMEN
- Thank you received: 104
28 Mar 2008 20:46 #202821
by PLUMMEN
Replied by PLUMMEN on topic GPz1100 Cams--Which one is intake/which is exhaust?
