New KZ Twin Owner looking for help with no start condition
- Qdude
- It is all good.
Re: New KZ Twin Owner looking for help with no start condition
25 Mar 2008 22:15
Are there two coils on a twin?
Would it have been impossible to have switched the coil wires up?
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- votumamor@gmail.com
25 Mar 2008 22:43
Qdude,
There is only one coil and yes, I forgot which wire went where. I tried both configurations and got the same result, BANG out the carbs. I checked the online manual and will correct that.
About the valve timing, you think 180 degrees off? I positioned everything according to the manual: I lined up the "T" on the spark advance and lined up the marks on the cam sprocket to be horizontal with the gasket surface, with the arrow pointing forward and the marks on the right side. Also made sure the notch on the camshaft was pointed to the rear per the manual.
Ima double check the manual but I'm pretty sure I got it right.
- bountyhunter
26 Mar 2008 09:45 - 26 Mar 2008 09:51
Qdude wrote:
No, only one coil.... but it is possible to get the spark timing 180 out if you removed the "cam" body that drives the points from the shaft and put it back on the wrong way.
Ask me how I know that....:laugh:
Last edit: 26 Mar 2008 09:51 by bountyhunter.
- bountyhunter
26 Mar 2008 09:47
Wires are reversible, they both spark on every upstroke.Qdude,
Impossible to set the valves 180 off on a twin as long as you set the valves on TDC. You can set the cams to either TDC on the four stroke cycle because both pistons go up and down together.
You did.Qdude,
- ronjones
26 Mar 2008 10:29
Had a similar problem getting my bike started 1st time, after rebuild. I put the timing advancer in 180*. After pulling it out and rotating it, she fired up.
- bountyhunter
26 Mar 2008 13:32
ronjones wrote:
Been there, done that.....:laugh:
01 Apr 2008 00:00
Ok here's what I found. The compression was very low due to damaged rings. They seemed to fit very tightly into the groove around the piston head. It didn't help when the cylinder head dropped on them upon re-install.
I've got many other projects to tend to, SO Ima let this one go. Its on Ebay now, search "81 Kawasaki KZ440 LTD" or "votumamor3" user name.
Electronic ignition for sale, nice seat, all the electricals are confirmed working, good cyl head, good tank and matching side covers, new brake master cylinder..... See pictures and descriptions on Ebay.
- steell
01 Apr 2008 04:32
bountyhunter wrote:
Add me to the list:blush:
ronjones wrote:Had a similar problem getting my bike started 1st time, after rebuild. I put the timing advancer in 180*. After pulling it out and rotating it, she fired up.
- Tyler
04 Apr 2008 13:08 - 04 Apr 2008 13:12
hmmm fresh parts....
"74 Yamaha DT 400 Enduro
Last edit: 04 Apr 2008 13:12 by Tyler.
