New KZ Twin Owner looking for help with no start condition
- votumamor@gmail.com
Battery is good. Haven't tested the compression but I do have some. Spark is good out of both wires. New gas, cleaned the carburetors, and am getting fuel. So, it turns over strong, but I'm getting ZERO combustion (even with a couple shots of starting fluid). Timing? Its electronic ignition. The mechanical spark advance assembly, I'm sure could stand lubrication, but looks good.
I've got a Clymer's manual en route, but as of now am stuck. What's my next move? Check the cam chain/alignment marks? The drive chain is off the bike. That wouldn't have anything to do with it would it?
Nice KZ site guys, glad I found it!
- bountyhunter
- Thank you received: 337
Just got a good deal on an '81 KZ440 LTD for $300. Its low mileage (apparently) 12k miles, has some new parts and I'd say is presentable. But it don't start YET!
Always check the compression first.
If the plugs are wet, and you have spark, that is about the only thing left.
- steell
Might be a cheap fix.
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
On your bike open the seat and grab the rear of the filter and try lifting it up, if it moves your filter is on wrong. There is a slot for lack of a better term on the airbox and the filter has to slide into that first before you install the two screws on the top. I'm just trying to save you from some future headaches.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Gringo, actually my air filter is missing right now. And the air box is missing the screws on the top to fasten it to the frame. I THINK I got a new air filter with the bike and will certainly install one asap after hearing your warning.
Steell, no I haven't yet, and I absolutely should. They look ok, no bad enough to keep it from running or sparking...but now that you bring it up it would be incredibly stupid not to...what 5 bucks and 10 minutes. Thanks for the reminder.
Hopefully I have good news and a running bike next time I post. Thanks all, cheers!
I'm working without a manual at the moment (its on order) but I'm assuming the two marks on the cam sprocket need to be parallel with the gasket surface (horizontal) and the arrow pointing forward. Can anybody confirm this?
So, from here I need to find TDC right? Then loosen the cam chain (tensioner?) and adjust the cam/sprocket to the correct position while retaining TDC. To find TDC on the compression stroke, do I just line up the "T" mark on the mechanical advance while on the compression stroke?
Not sure how to post pictures on here, but here's a link to some pictures of what I'm talking about.
s275.photobucket.com/albums/jj282/xtreasurehunter/
- Iceman Too
- Even the finest shoe makes a poor hat
Iceman
1979 KZ 1300 (Under Repair)
1999 V-Max (Gonna ride it till the Kow comes home)Sold Kow came home
1980 KZ1300 B2 Touring
Nova Scotia
- bountyhunter
Took a look at the cam sprocket and timing marks and they appear way off to me. I also spoke the previous owner, and he confirmed removing the cam while replacing all the engine gaskets.
On my 750 twin the TDC alignment of the cams is to have the arrows parallel to the head top, the intake arrow points to the rear, the exhaust arrow points to the front. On mine, you can then rotate the crank one revolution back to TDC again and the arrows will be pointed towards each other (still parallel to head).It may look like the cams are 180 out of time at that point, but they are not. On the twins, you can align the cams to either TDC position of the piston set.
- bountyhunter
YES. Understand, TDC on the twin's pistons is the same for either stroke. It doesn't become "TDC for the compression stroke" until you put the cams in. You can align cams on either crankshaft TDC.
I'm very optimistic about having a running bike shortly. Appreciate all the help guys and I'll let you know what happens.
compression test
clean out tank and fresh gas
new air filter
new plugs
clean carbs again
reset mixture screws
rebuild petcock (leaking slightly)
Am I missing anything?
- Qdude
- It is all good.
77 KZ 650 C1.
77 KZ 650 C1.
