79 KZ10000st stator wire seal leaking
- steveskz
15 Mar 2008 07:22
Would like to know if there is a replacement seal I can get or sealer I can use, I used blue permatex and that was a mistake could be the only reason its leaking now? Thanks Steve:(
- NickW900LTD
- Nick
Re: 79 KZ10000st stator wire seal leaking
15 Mar 2008 08:57
its leaking cause its old!!!! Z1 enterprises has what you need!!
www.z1enterprises.com/detail.aspx?ID=373
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- squints
15 Mar 2008 09:41
i have the same problem. changed the stator, put a new gasket in and there's a small drip drip drip. I'm going to get a new grommet and replace the old one, but, when would I want to use this???
www.z1enterprises.com/detail.aspx?ID=178
should I use this in addition to the grommet, or should a new grommet do the trick?
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
Upstate NY
- NickW900LTD
- Nick
15 Mar 2008 10:39
i replaced my stator gasket without replacing the grommet and now oil blows everywhere, so now i have to replace the stator gasket and get a new grommet. I should have done it the first time.
1977 KZ1000 LTD
1978 KZ1000 A2A
1977 KZ1000 LTD
1978 KZ1000 A2A
- steveskz
- FloridaBiker
15 Mar 2008 13:17 - 15 Mar 2008 13:18
You do not need to replace the grommet, (although it helps).
Remove the cover, and clean all the old sealer you put in there trying to stop leak.
I use high temperature silicone seal. It is about $4 a tube from the parts house.
Slide the grommet about 2" away from the cover and clean the wires and grommet thoroughly. I like aerosol carb cleaner as it dries without residue.
Slide the grommet back into position.
Then clean the wires again in the area the grommet just slid over.
Put NO silicone inside the cover.
Put a small amount of silicone in the groove around the grommet before you slide it into the housing.
Put a tie wrap around the wires about 1" from the grommet.
Bolt the housing on before the silicone dries.
Wait until the silicone is dry and then work a small amount of silicone around the wires between the tie-wrap and the grommet. Make sure you have completely covered the grommet and sealed it to the case.
I have done this on 6 KZs in the last year and all seal perfectly.
Last edit: 15 Mar 2008 13:18 by FloridaBiker.
- Sandy
- Fly High,Tony
16 Mar 2008 15:22
FloridaBiker wrote:
Good info FB.
I'll be doing the same thing as soon as I get my parts in.
I had the same problem with mine.I put a brand new one in last season,and even with siliconing like you said,the dam thing still dripped.I'll have to try the zap-strap and see if that helps when I install the new one...thanks.
Good info FB.
1977 KZ1000 A-1
- roystaylor
17 Mar 2008 21:18
You certainly do need to replace the grommet, and you do need to part the wires, and you do need to go back with a ne w alternator gasket. Also, use the 3-bond sealer on all cleaned surfaces and allow to cure. Not doing this will result in the same problem you are experiencing now.
Get some shrink insulation pieces from the auto parts or Raddio shack to go over the wires when you solder them back together.
It would be silly to do otherwise. Do it right the first time or find a supplier of left handed shoes, because your engine will drool oil on them otherwise.
Best regards, from someone who had this happen before.
- Sandy
- Fly High,Tony
17 Mar 2008 21:31
Thanks Roy.
Yes,I for sure did use shrink-tube on the soldered connections,and I also used a high-heat(black) silicone on the surfaces where the grommet sits in,and I also used it on the outside of the wires,but it still leaked(only from the grommet area).I let it all cure for a least a full day,too.
I've never used any of the three-bond products,but I know it's a heck of a lot cheaper than Yamabond!
I'll be getting some of the three-bond when I order my stuff from Jeff.
1977 KZ1000 A-1
- coppertales
19 Mar 2008 12:48
Either get a new seal or take the old one and degrease it well then smear permatex no 2, the black sticky stuff, around the wires and surfaces and stick it back in. The silicon based sealants just don't do the job....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- violentvintagecycles
19 Mar 2008 16:36
Am i crazy or am i wrong in thinking that the stator assembly DOESNT run in oil? If oil is leaking out of there isnt there a seal that keeps oil OUT of the stator assembly?
- Sandy
- Fly High,Tony
19 Mar 2008 16:40
Nope...the stator(alternator,dynamo) IS a wet system,meaning that there IS oil in that area,behind the cover.
1977 KZ1000 A-1
