Broken spark Plug
- Fratedog
Ran into a small glitch. I was trying to get a plug out and it broke off. Only the thread part stayed in the head. The ceramic and spark came out. How the hell do I get that out???
:dry:
Or do I just have to buy a new head? This is a 1976 KZ900 LTD BTW.
Thanks
Fratedog
- bountyhunter
- Thank you received: 337
- kano
- Not Another Bloody Limey!
anyway this is what they look like i have a set and there worth getting just in case.
- Fratedog
I am know about the extractors. Problem is the plug was stuck HARD and I could not get enough torque with the wrench
I soaked it in WD-40 for a day and then used a pipe to extend the handle of the wrench. That is when it broke. Do you think the extractor will still work?
Thanks
Fratedog
- Bluemeanie
- Thank you received: 14
- FloridaBiker
- Thank you received: 4
But first;
Soak the plug with a quality solvent.
I really like PB Blaster.
It is a much better product than WD40.
Put the extractor into the plug.
Then you need to warm the head.
A heat gun or bottled propane torch works.
CAUTION:
If you are using the open fire route use some common sense. No gas tank or carburetors please!
The heated head will expand slightly and remove some pressure on the plug.
spray it again with solvent and then try the extractor.
Good luck!!
- Fratedog
Fratedog
- 77KZ650
- Thank you received: 7
07 MDP Rookie of the Year
- mark1122
- Keep twisting it
- Thank you received: 109
You may have to pull the head.
But first;
CAUTION:If you are using the open fire route use some common sense. No gas tank or carburetors please!
Good luck!!
i would say that this is very good advice.may i just add that u should give it a good smack with a hammer to try and shock it loose just before u try to turn it out. seriously. this will actualy help.if it still wont come out u will have to follow bluemeanie's advice and drill it out.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- FloridaBiker
That is excellent advice, and I was remiss in not saying so.
Thx mark1122!
- Becker
- The Doctor Will Rise Again
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- MDawnz1
- Thank you received: 27
Everyone is right , it's either seized or crossed in the hole.
I hope it's an outside plug (easier to work on )
I saw some new stuff from a company that I trust ,but have NOT had a chance to try yet .
I know I'm not supposed to use name brands ,,,
but if the moderators will let this by ,,,
The stuff is "CRC FREEZE OFF Super Penetrant"
It uses COLD instead of heat to break the seal between the two metals .
IF you can't get it out , do yourself and your bike a favor and pull the head and take it to a GOOD machine shop and have then put in a "plug thread insert"
good luck
1974 Z1a, still 903
