Spun a rod bearing
- kxhonda
Spun a rod bearing
03 Mar 2008 16:58
Well I finally got my motor torn apart after it locked up on me recently. It spun a rod bearing on #4. Luckily I got it torn down just in time to find and win this bad boy,
cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll...em=380000315644&rd=1
Heres the bearings.
Post edited by: kxhonda, at: 2008/03/03 20:01
Heres the bearings.
1977 Kz650B1 #576th made.
Warsaw, In
Warsaw, In
- kxhonda
- kxhonda
Re: Spun a rod bearing
03 Mar 2008 17:06
And prob my favorite part of this whole rebuild.
650 cylinders on the left, 750 clylinders on right.
Warsaw, In
Warsaw, In
03 Mar 2008 17:10
Any ideas on what caused the problem to occur?
03 Mar 2008 17:54
650ed wrote:
Caution -- unsolicited opinion follows :lol:
Perhaps not the underlying cause in this instance, but am thinking one reason for rod bearing failure could be from gasoline intrusion into the crankcase oil. There have been several recent forum discussions regarding excessive fuel in the float bowl (for whatever reason the excess incoming fuel is not all being discharged by the overflow system) which excess fuel rises up into the carb bore and flows both ways, forward into the combustion chamber (then down around the pistons into the crankcase) and backward into the airbox (then down through the crankcase vent hose into the crankcase. This condition of fuel intrusion into the crankcase oil may occur while the bike is parked or during normal riding. So anytime a floatbowl overflow is noticed, it is usually a good idea to sniff-check the crankcase oil for any gasoline odor, and if so, change the oil and filter (plus correct the overflow problem). Another indication is an unexpected increase in oil level when viewed through the sight glass. And the fuel-contaminated oil will also likely be thin and watery.
This gets particularly critical with Mikuni smoothbore carbs which have no floatbowl overflow provision. I think it's the primary reason smoothie users run the crankcase vent tube to directly underneath the bike or anywhere besides into the airbox.
- steell
03 Mar 2008 18:22
I just checked and I have been a member here for 1 month shy of 4 years,
and up until last week I don't recall any post on any 650 spinning
a rod bearing, and now there's two separate threads. I certainly
hope this doesn't indicate a trend
I think Patton has a point, I always turn off
the petcock when I shut off the motor. I'm
glad the 750B's have on/off/reserve petcocks
and not vacuum operated.
Post edited by: steell, at: 2008/03/03 21:23
- kxhonda
03 Mar 2008 20:11
I'm not real sure why it happened. I started to hear the rod knock mid summer. I put 2500 miles on it after that until it locked up. I changed the oil when I started hearing it knock. There wasn't any noticable amount of gas in the oil. I always turn my petcock to off.
Warsaw, In
Warsaw, In
- kxhonda
03 Mar 2008 20:53
Just bought a stud extractor to so I can get the top case to work so I can bore it out for the 750 cyclinders. Just about ready to order the 810 kit.
Will I still be able to run pump gas running the 650 head without pinging and overheating? I am also putting a oil cooler on it. Anybody got a gpz750 oil pan they would like to get rid of? :whistle:
Warsaw, In
Warsaw, In
- BSKZ650
04 Mar 2008 05:37
anytime I have seen a bearing failure due to fuel in the oil, all the bearings show signs of heat and the one that fails has a lot of gaulding on the bearing surface, this is due to lack of lubrication properties of the oil.
most of the time you see a bearing failure like that its caused by oil pumps going bad, and not keeping up with the demand of the motor.
On a small block chevy, rod bearings 5 and 6 will be the first to go when they loose oil pressure,
I would be rebuilding or replacing the oil pump for sure
77 ltd1000, current rider
76 kz900, just waiting
- kxhonda
04 Mar 2008 20:42
Took the oil pump apart tonight. Clearances all checked out good. No scratches inside. I'd say its good.
Warsaw, In
Warsaw, In
- NickW900LTD
- Nick
04 Mar 2008 20:54
hey kx, i live in pierceton really close to you, goodluck on your motor work!!!
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- NickW900LTD
- Nick
04 Mar 2008 21:02
1977 KZ1000 LTD
1978 KZ1000 A2A
1977 KZ1000 LTD
1978 KZ1000 A2A
