What is the Difference between "J" motor and 84 GPZ1100
- otakar
Post edited by: otakar, at: 2008/02/14 18:05
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- PLUMMEN
- Thank you received: 104
- steell
I have a 83 GPz1100 block that is planned to go an a J motor (998cc), but I'm still trying to get the J motor here.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- FloridaBiker
- Thank you received: 4
Can I put a "J" crank in a 84 GPZ case? can I Put a 84 tranny in a 81 case and so on.
Yes, in both cases.
Everything will fit in your examples.
A GPZ is a J motor, just better cams,pistons etc.
I believe, (but am not sure)that early J motors have a smaller piston pin diameter than later models.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- FloridaBiker
Yes, definitely........Are the main cases the same between the sahft and the chain drive engines?
I think the only difference is the transmission output shaft.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- steell
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- FloridaBiker
There is a monkey wrench to your plan.I was wondering if a shafty could be converted to a chain drive system by changing the shaft drive cover system and the swing arm and wheel.
The transmission output shaft is different between the shaft and chain bikes.
You will need to split the cases and install the output shaft that allows mounting of the chain sprocket.
It is possible you could machine something to work without splitting the cases. Sounds like the kind of challenge I like..
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
