What is the Difference between "J" motor and 84 GPZ1100
  • otakar
  • otakar's Avatar Topic Author
14 Feb 2008 15:00
#194628
Besides the obvious, such as the displacement and the Head, what are the lower end, and mid section differences between the J motor and its successor. Are any of the parts interchangeable? I also of course know about the 17mm and 18mm wrist pins. Are the crank cases the same or interchangeable? Are the cylinders interchangeable? I also know about the 1/4mm longer stroke on the newer engine, which would result in a 1/8mm taller cylinder block. Etc. Etc.
Post edited by: otakar, at: 2008/02/14 18:05
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • PLUMMEN
  • PLUMMEN's Avatar
Re: What is the Difference between \"J\" motor and 84 GPZ1100
14 Feb 2008 19:59
#194680
i dont know what all interchanges but ive got a set of 1170 pistons and block just waiting for a cheap 84 gpz to put them on!:P
  • steell
  • steell's Avatar
15 Feb 2008 05:15
#194703
To the naked eye, both cylinder blocks appear to be the same height, but I can't see a .005" difference just by looking :)
I have a 83 GPz1100 block that is planned to go an a J motor (998cc), but I'm still trying to get the J motor here.
  • otakar
15 Feb 2008 05:38
#194706
I am realy interrested in the lower end differences. IE Can I put a "J" crank in a 84 GPZ case? can I Put a 84 tranny in a 81 case and so on.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • FloridaBiker
  • FloridaBiker's Avatar
15 Feb 2008 09:39
#194735
Yes, in both cases.
Everything will fit in your examples.
A GPZ is a J motor, just better cams,pistons etc.
I believe, (but am not sure)that early J motors have a smaller piston pin diameter than later models.
  • otakar
15 Feb 2008 10:16
#194740
OK that sounds good. Now next question; Are the main cases the same between the sahft and the chain drive engines?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • FloridaBiker
16 Feb 2008 05:56
#194862
otakar wrote:
.......Are the main cases the same between the sahft and the chain drive engines?
Yes, definitely.
I think the only difference is the transmission output shaft.
  • otakar
16 Feb 2008 07:40
#194878
Thats the ticket. I was wondering if a shafty could be converted to a chain drive system by changing the shaft drive cover system and the swing arm and wheel. I have the parts for the conversion if they fit as hoped.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • steell
  • steell's Avatar
16 Feb 2008 14:21
#194973
I'm not certain but I think the frames are different also. I don't believe that the chain drive swingarm will bolt on the shaft drive frame.
  • otakar
16 Feb 2008 14:29
#194977
Frames are no problem. Nothing a good torch can't cure.:whistle:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • FloridaBiker
16 Feb 2008 16:57
#195005
There is a monkey wrench to your plan.
The transmission output shaft is different between the shaft and chain bikes.
You will need to split the cases and install the output shaft that allows mounting of the chain sprocket.
It is possible you could machine something to work without splitting the cases. Sounds like the kind of challenge I like..
  • otakar
18 Feb 2008 04:08
#195294
Splitting the cases, I do not consider a "MunkiWench" Only a slight inconvenience. eBay here I come. "Here Output shaft where are you"?:lol:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
