Degreeing aftermarket cams
- inline4
11 Feb 2008 18:13
For some reason this procedure is intimidating the hell out of me (but probably not as much as my electrical issues:ohmy: )
Here is my starting point:
'74Z1A; Wiseco 1015cc, 10.25:1CR pistons; Kenny Harmon D grind cams; complete Dyna S ignition; slotted cam sprockets.
Where the hell is the starting point for this set-up?
The time has come to "degree in" the cams but I don't have a clue as to a starting point.
I even bought a cam degreeing dvd from Dale Walker's Holeshot Performance, but he seems to be degreeing an engine that is already set up!
This project is approaching FOUR YEARS OLD! I really need to get this Z on the road. I now have a CB550K and a CB200T that I want to 'cafe", but I must get this project up and running before I get involved in another.
Is there a thread here that I have overlooked?
I'm depending on you guys for your help.
Remember, I've been in the wine and liquor business for over 30 years. There ARE perks, you know! Not that I'm trying to bribe anyone or anything.:whistle: :whistle:
- Sandy
- Fly High,Tony
Re: Degreeing aftermarket cams
11 Feb 2008 19:16
Inline...do you have the specs for the cams you have?
You'll need that info before you can do anything with those cams,bud.
I had a friend of mine help me with mine,and ya...it is quite a process,but for him it was easy,as he had done it many times before.
You'll need a degreeing wheel,and a top-dead-center gauge.
Anyway...the specs will be something like the attached pic...
(sorry I can't be more help)
Post edited by: Sandy, at: 2008/02/11 22:17
1977 KZ1000 A-1
- PLUMMEN
11 Feb 2008 19:53
yep,gotta have a starting point;)
- inline4
11 Feb 2008 20:06
I've got all the necessary tools to do the job;
just lack the know-how.
I'm ready to give up on those cams and go with something else. Hell, it's only money, right?:whistle: :whistle:
- elseed
11 Feb 2008 20:20
Inline -- Was in the same spot some time ago, my project forcing me into new things. I bent a couple (brand new) valves (on my fresh head) due to severe stupidity once, so I can see where you're coming from. Guys already told you about getting a target - specs in terms of intake/exhaust degrees.
But I recall the Holeshot video being fairly helpful actually, if you ignore the fact that he's dealing with a drag bike. The cam math isn't bad and fun really, once you wrap your head around it. One step at a time, keep checking the video...
One problem I had, though I have oversize valves, was the positive stop tool could make contact with the intake valves. Also, you hafta fool around to make the dial indicator clear everything -- maybe bend the extension a bit to get around the cam. Make yourself some kind of steel plate fixture bolted into the valve cover holes to firmly mount the magnetic dial indicator. One other thing: I recall preferring to use the ignition side of the engine for mounting the dial to avoid taking off my leaky generator cover again.
Overall advice: If the engine doesn't seem to wanna turn, STOP!! Look things over again.
I'll poke around and see if I have any helpful links. But check that video again, get yerself setup: valve cover off, cam sprockets somewhere about the middle of the slots, standard cam mounting procedures to start (by the manual), get cam caps bolted down in approx. stock timing (your sprockets marked?), mount the dial, make an indicator needle, etc., etc., etc.
'75 Z1B with mods
- Sandy
- Fly High,Tony
11 Feb 2008 20:34
I'm checking with "Dragbike.com" right now,but the search function appears to be down.I keep getting a "Timed out".
Don't give up Jim.Like elseed said...one step at a time.
I feel bad,becaus it was Me that sold those cams to Jim.We just figured that out in a u2u,lol:laugh:
Hmmm...I wonder how those cams would compare to the 410's I have?(attached specs above)...Elseed?...
1977 KZ1000 A-1
- 77KZ650
11 Feb 2008 20:46
click here
written by the one and only Doug MeyerB)
07 MDP Rookie of the Year
- Sandy
- Fly High,Tony
11 Feb 2008 21:12
Just so you know,Jim(and a reminder if I already told you)...those cams came out of a 74 900 with a 1000 top end...the shim-bucket areas WERE clearanced,and the shim set-up WAS "shim over bucket",so one can only ASSUME that the cams are of a tamer grind.
1977 KZ1000 A-1
- 77KZ650
11 Feb 2008 21:16
why dont you just mic the lift and find out for sure?
- Sandy
- Fly High,Tony
11 Feb 2008 21:25
77KZ650 wrote:
That's a good idea,and a good start.
What's the base circle measurement?I'll have to look that up again.
We could try that,Jim...and compare?...:huh:
(110 base circle)
Post edited by: Sandy, at: 2008/02/12 00:29
(110 base circle)
1977 KZ1000 A-1
- 77KZ650
11 Feb 2008 21:33
mic the biggest part of the lobe, then mic the lobe 90 degrees from that, it should be the smallest part. subtract the small number from the big numer and you have the amount of lift. you can figure out duration with the degree kit
- Sandy
- Fly High,Tony
11 Feb 2008 21:39
Here's some more info,Jim...from APE...
www.aperaceparts.com/COPE.HTML
Scroll down to "Cams"...close to the top of the page.
1977 KZ1000 A-1
