KZ750-4 Exhaust Parts Interchangability with 550 ?
- 2M4Dale
08 Jan 2008 18:39 #188330
by 2M4Dale
Hello from Sunny Mansfield, Ohio
1980 KZ750H1 LTD
1981 KZ750H2 LTD
KZ750-4 Exhaust Parts Interchangability with 550 ? was created by 2M4Dale
I just found a stock exhaust system for my 1980 KZ750 H1 LTD. My bike currently has a MAC header ... I need a set of exhaust sleeves and collars to mount the stock exhaust ... will these parts >>>
Will These Work?
>>> from a 1983 Spectre 550 work on my 750 ???
Post edited by: KZCSI, at: 2008/01/09 08:42
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- Bluemeanie
- Thank you received: 14
08 Jan 2008 19:16 #188339
by Bluemeanie
Replied by Bluemeanie on topic KZ750-4 Exhaust Parts Interchangability with 550 ?
Exhaust holders for your 750 fit these other bikes...
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-G1 (LTD II) (1980)
KZ750-K1 (LTD Belt) (1983)
KZ750-K2 (Canada Only) (1984)
KZ750-M1 (CSR Twin) (1982)
Exhaust holders for the '83 550 fit these bikes...
EX250-E1 (Ninja 250R) (1986)
EX250-E2 (Ninja 250R) (1987)
EX250-F2 (Ninja 250R) (1988)
EX250-F3 (Ninja 250R) (1989)
EX250-F4 (Ninja 250R) (1990)
KZ550-F1 (Spectre) (1983)
KZ550-F2 (LTD Shaft) (1984)
KZ550-M1 (LTD Shaft) (1983)
KZ750-F1 (LTD Shaft) (1983)
KZ750-L3 (1983)
ZL600-A1 (ZL600 Eliminator) (1986)
ZL600-A2 (ZL600 Eliminator) (1987)
ZL600-B2 (Eliminator 600) (1996)
ZL600-B3 (Eliminator 600) (1997)
ZR550-B1 (Zephyr) (1990)
ZR550-B2 (Zephyr) (1991)
ZR550-B3 (Zephyr) (1992)
ZR550-B4 (Zephyr) (1993)
ZX600-A1 (Ninja 600) (1985)
ZX600-A2 (Ninja 600) (1986)
ZX600-A3 (Ninja 600) (1987)
ZX600-B1 (Ninja 600RX) (1987)
ZX600-C1 (Ninja 600R) (1988)
ZX600-C10 (Ninja 600R) (1997)
ZX600-C2 (Ninja 600R) (1989)
ZX600-C3 (Ninja 600R) (1990)
ZX600-C4 (Ninja 600R) (1991)
ZX600-C5 (Ninja 600R) (1992)
ZX600-C6 (Ninja 600R) (1993)
ZX600-C7 (Ninja 600R) (1994)
ZX600-C8 (Ninja 600R) (1995)
ZX600-C9 (Ninja 600R) (1996)
So I guess not.
Post edited by: Bluemeanie, at: 2008/01/08 22:17
KZ750-B1 (1976)
KZ750-B2 (1977)
KZ750-B3 (1978)
KZ750-B4 (1979)
KZ750-L3 (1983)
So I guess not.
- 2M4Dale
09 Jan 2008 03:18 #188365
by 2M4Dale
1980 KZ750H1 LTD
1981 KZ750H2 LTD
Replied by 2M4Dale on topic KZ750-4 Exhaust Parts Interchangability with 550 ?
hmmmm .... OK, Thanks !!! I'll keep looking !
1980 KZ750H1 LTD
1981 KZ750H2 LTD
- steell
09 Jan 2008 05:32 #188374
by steell
Replied by steell on topic KZ750-4 Exhaust Parts Interchangability with 550 ?
Bluemeanie, you looked up the wrong 750
The 1980 750 four is actually listed as a 740 on kawasaki.com.
Here's the actual list that uses the same holders as the 80 750H1.
KL250-A1 (KLR250) (1978)
KL250-A1A (KLR250) (1978)
KL250-A2 (KLR250) (1979)
KL250-A3 (KLR250) (1980)
KL250-A4 (KLR250) (1981)
KLF185-A1 (Bayou 185) (1985)
KLF185-A1A (Bayou 185) (1985)
KLT160-A1 (KLT160) (1985)
KLT185-A1 (KLT185) (1986)
KLT185-A2 (KLT185) (1987)
KLX250-A1 (KLX250) (1979)
KLX250-A2 (KLX250) (1980)
KZ200-A1 (1978)
KZ200-A1A (1978)
KZ200-A2 (1979)
KZ305-A1 (CSR) (1981)
KZ305-A2 (CSR) (1982)
KZ305-B1 (CSR Belt) (1982)
KZ305-B2 (LTD) (1987)
KZ305-B3 (LTD) (1988)
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ550-C1 (LTD) (1980)
KZ550-C2 (LTD) (1981)
KZ550-C3 (LTD) (1982)
KZ550-C4 (LTD) (1983)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-C1 (Custom) (1977)
KZ650-C2 (Custom) (1978)
KZ650-C3 (Custom) (1979)
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
KZ650-F1 (1980)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-H1 (LTD) (1980)
KZ750-H2 (LTD) (1981)
KZ750-H3 (LTD) (1982)
KZ750-H4 (LTD) (1983)
KZ200-A1 (1978)
KZ200-A1A (1978)
KZ200-A2 (1979)
KZ550-A1 (1980)
KZ550-A2 (1981)
KZ550-A3 (1982)
KZ550-A4 (1983)
KZ650-B1 (1977)
KZ650-B2 (1978)
KZ650-B2A (1978)
KZ650-B3 (1979)
KZ650-F1 (1980)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
- Bluemeanie
09 Jan 2008 05:51 #188376
by Bluemeanie
Oh, I guess I should have known that!:S Why would it be under 740? Is it because 750's are actually I believe 722's?(or close to that) Well that's good news for 2M4Dale.
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
09 Jan 2008 06:41 #188393
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic KZ750-4 Exhaust Parts Interchangability with 550 ?
One note of caution here Dale, while Steell's Info on the flanges is correct (the 550's and 750's use the same flange) the split keepers are different. If you look at the headpipes on your exhaust you should see a wider metal ring built into the side of the pipe, this is about a 1/2" thick. Because of this you will need a set of collars that are shorter than what is used on the 550's and 650's. I went thru this when I put the ZR7 exhaust on my 650 C-1. Not a huge deal they are still available from Mother Kaw IIRC they run about $3.00 each and you need 8 of them so you are looking at spending around another 30 bucks. Also the flanges you linked to are the flat smooth type where the correct ones for your bike are finned, I don't know if that makes any difference to you or not.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- steell
09 Jan 2008 07:52 #188403
by steell
Bluemeanie wrote:
750's are 738cc, and I have no idea why Kawasaki lists the 80-82 750's under 740 and the 83 on as 750's. Maybe because they already had the 750 twins listed under 750?
- 2M4Dale
09 Jan 2008 14:11 #188456
by 2M4Dale
1980 KZ750H1 LTD
1981 KZ750H2 LTD
Gringo ... if the sleeves just need to be shortened ... well hey !!! I'm a machinest ... I can do that !
Oh and smooth vs. finned ... don't really matter to me but I honestly think I like the smooth better. My bike isn't exactly stock anymore anyways.
And to top things off ... I may not use this stock system on my KZ anyways. Just playing around a bit. I do have a parts bike (thanks Gringo) that could be potentially restored someday as well.
Thanks guys for the help ... I'm gonna pull the Ebay trigger on these I think.
Post edited by: 2M4Dale, at: 2008/01/09 17:17
1980 KZ750H1 LTD
1981 KZ750H2 LTD
